![]() ![]() Drives: Hatch Join Date: May 2009
Hey, speaking of drain plugs. Do you guys torque your drain plug?
I try to torque everything. I started out torquing it to spec, 28 ft lbs, but after about 10 years it became pretty hard to crack loose, so I started torquing at 20 ft lbs. which was good. I just changed my oil yesterday and the plug was a bit hard to crack loose. I am a little nervous about going lower than 20 ft lbs. Any thoughts? |
| crush washer on drain plug? | 2007yariz | DIY / Maintenance / Service | 17 | 10-06-2024 02:10 PM |
| Bigger Spark plug? | samuraivince | Performance Modifications | 6 | 08-05-2014 04:09 PM |
| Review: Magneticdrainplug.com's magnetic drain plug | schleppy | DIY / Maintenance / Service | 13 | 04-21-2009 12:04 AM |
| motor oil drain plug washer | xpeteyjtx | DIY / Maintenance / Service | 13 | 12-30-2008 01:27 PM |
