Old 05-21-2011, 11:37 AM   #1
2007yariz
Drives: Yaris sedan
Question crush washer on drain plug?
Hello, Does the Yaris come with a crush washer on the drain plug from the factory? I did 2 oil changes so far on the Yaris, and a few on a 02 Corolla, guess what, both of them don't have a crush washer! Maybe the guy at the shop just tossed them away? Should i get one for my next oil change? Thanks.
2007yariz is offline   Reply With Quote
Old 05-21-2011, 11:42 AM   #2
Brian
Brian's Avatar
Yes, it comes with one. You can buy them for about $.50. I always replace mine at every oil change.
Old 05-21-2011, 12:25 PM   #3
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
no crush washer huh? you got any leaks....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 05-21-2011, 12:34 PM   #4
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
thats what im thinking any leaks i know when i did the auto trans drain i tryed using the old crush washer and it dripped slightly so now i have extra drain plug and washers just in case for oil and trans
pennyracer is offline   Reply With Quote
Old 05-21-2011, 12:51 PM   #5
2007yariz
Drives: Yaris sedan
Nope, No leaks on both vehicles, i just put the plug back on. I will get a drain plug crush washer soon from a dealer.
Old 05-21-2011, 01:08 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Mine doesn't have one. No leaks either.
Old 05-22-2011, 10:55 PM   #7
auxmike
auxmike's Avatar
They tend to stick to the oil pan and not stay with the plug. I always have to tap them off the bottom of the pan with a screwdriver or wrench. They are an aluminum washer sandwiched between grey paper.
Old 05-24-2011, 01:16 PM   #8
severous01
should be included in oil filter if there's one on the car. mine has a rubber gasket i think. idk...it's only been 6 months since my last oil change
Old 05-27-2011, 12:43 PM   #9
2007yariz
Drives: Yaris sedan
I changed my oil yesterday, and i saw there was a silver washer permanently attached onto the black oil pan. Right by the drain hole. Anyone else noticed it?
Old 07-08-2012, 10:35 AM   #10
08yarisman
Drives: 2008 yaris
mine has the same thing..was worried that there was no gasket..but that must be it.
08yarisman is offline   Reply With Quote
Old 07-08-2012, 11:39 AM   #11
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Same here. I did the first oil change on my 2012 and was searching the oil pan for the washer when it was stuck on the pan!
I just left it stuck there and put the plug back in. No leak.
Old 06-01-2023, 06:40 AM   #12
keloj
Drives: toyota yaris
The presence of a crush washer on the drain plug can vary depending on the specific model and year of the Toyota Yaris. While some vehicles come from the factory with a crush washer on the drain plug, others may not. It's possible that the previous oil changes were done without a crush washer, or the washer may have been discarded during those service visits.
keloj is offline   Reply With Quote
Old 06-01-2023, 11:06 AM   #13
thetut
Drives: 2007 4dr sedan
Go to toyodiy.com and enter your VIN in the Parts reference page and search for GASKET(FOR OIL PAN DRAIN PLUG)
This will tell you if it should have one or not.
thetut is offline   Reply With Quote
Old 06-02-2023, 01:18 PM   #14
remcafee
the drain plug gasket on the yaris from the factory is a blue felt type material gasket, it is one time use and must be replaced after every oil change, it is by far the best gasket as it does a good job to not scratch up the surface of the oil pan or drain plug itself
Old 06-07-2023, 02:20 AM   #15
IndestructibleYaris
Never replaced a crush washer in my life and I've never had a come back or an oil leak on friends or family vehicles.
IndestructibleYaris is offline   Reply With Quote
Old 06-08-2023, 02:09 PM   #16
sh0rtlife
mostly true, really depends on the last monkey who tightened it....with the exception of aluminum oil pans tending to need to have them replaced
Old 09-21-2024, 03:45 PM   #17
robkay
Drives: Hatch
Thanks for commenting on that. I was just wondering about this. Years ago I had asked a guy I was acquainted with, who owned an auto shop, whether it was necessary to change it every time. He said, "Nah!"
I've always done it anyway, but next change I think I'll try just reusing the one that's on there. Maybe change it every 3rd time or something.
robkay is offline   Reply With Quote
Old 10-06-2024, 02:10 PM   #18
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
My Yaris is a 2010 Hatchback. I've done my own oil changes. Back in April (2024) I noticed the crush washers I had just purchased from the local Toyota dealership were these " blue felt looking aluminum" type. Did an oil change yesterday on both my Yaris and 07 FJ. Both blue type crush washers had to be removed with a putty knife; they were stuck on the oil pan. Before April 2024 I recall the crush washers were a dark color, possibly black?. Also, I noticed both drain bolts had lost torque/ tauntness......never occurred when using the "darker ones" of the past. Anyone know if the darker ones can be bought thru dealership?, if so, part number please. TIA
frog13 is offline   Reply With Quote
Tranny Fluid/Oil Drain Plug Questions WankelsRevenge DIY / Maintenance / Service 3 03-08-2011 04:01 PM
Review: Magneticdrainplug.com's magnetic drain plug schleppy DIY / Maintenance / Service 13 04-21-2009 12:04 AM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
motor oil drain plug washer xpeteyjtx DIY / Maintenance / Service 13 12-30-2008 01:27 PM
