Old 10-06-2024, 02:10 PM   #1
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Originally Posted by remcafee View Post
the drain plug gasket on the yaris from the factory is a blue felt type material gasket, it is one time use and must be replaced after every oil change, it is by far the best gasket as it does a good job to not scratch up the surface of the oil pan or drain plug itself
My Yaris is a 2010 Hatchback. I've done my own oil changes. Back in April (2024) I noticed the crush washers I had just purchased from the local Toyota dealership were these " blue felt looking aluminum" type. Did an oil change yesterday on both my Yaris and 07 FJ. Both blue type crush washers had to be removed with a putty knife; they were stuck on the oil pan. Before April 2024 I recall the crush washers were a dark color, possibly black?. Also, I noticed both drain bolts had lost torque/ tauntness......never occurred when using the "darker ones" of the past. Anyone know if the darker ones can be bought thru dealership?, if so, part number please. TIA
frog13 is offline   Reply With Quote
Tranny Fluid/Oil Drain Plug Questions WankelsRevenge DIY / Maintenance / Service 3 03-08-2011 04:01 PM
Review: Magneticdrainplug.com's magnetic drain plug schleppy DIY / Maintenance / Service 13 04-21-2009 12:04 AM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
motor oil drain plug washer xpeteyjtx DIY / Maintenance / Service 13 12-30-2008 01:27 PM
