Old 06-13-2025, 03:21 AM   #1
Calkich
Drives: Honda Civic
Intermittent ABS activation at low speeds is a classic sign of a faulty or misread wheel speed sensor, even if th toe rings look find. The color difference may just be a batch or supplier code, not an indicator of OEM vs. a solid replacement part. Since the left side looks newer, you could start by swapping the left and right frond sensors to see if the problem transfersto either side.
Calkich is offline   Reply With Quote
My turn with ABS issue IllusionX DIY / Maintenance / Service 2 01-08-2015 01:20 PM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
CONSUMER REPORTS : March issue : 2010 YARIS sedan Hershey General Yaris / Vitz Discussion 41 02-18-2011 03:41 AM
