Old 01-08-2015, 10:46 AM   #1
My turn with ABS issue
So, we had a huge ice storm in the past week. Felt one of my wheel seems to lock up, but I didn't pay much attention. No ABS Light though.
Today, extreme cold. Drove a bit and poof! ABS and Brake light all on! ABS not working.
I guess I will have to crawl under there to check out the connector.
Not bad as my yaris is almost 9 years old now.
Old 01-08-2015, 11:28 AM   #2
check out the connector and clean it up with a cleaner. This should fix the issue as it likely isn't a damaged sensor, just dirty.
I have yet to have any ABS related issues but my Yaris is only starting on 7 years now
Old 01-08-2015, 01:20 PM   #3
It probably is a dirty/rusting connector. Parked for 2hours and first drive down the iced parking lot. ABS kicked in and turned off the light.
Wow! I guess I'll have to keep you guys updated.
Passenger airbag light on making turn signals and cabin fan not blowing? thatbryanguy General Yaris / Vitz Discussion 17 08-16-2024 10:23 AM
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
Using a relay for remote turn on jessewilliams In Car Entertainment + Electronics (audio / video / alarm) 6 08-26-2012 01:27 AM
Projectors retrofit, black reflectors and dimmed front turn signals my2sense General Yaris / Vitz Discussion 11 06-20-2012 11:39 AM
Does your liftback have ABS? BensVitz General Yaris / Vitz Discussion 75 05-24-2011 07:11 PM
