Old 09-02-2025, 10:45 AM   #1
Showtyme400
Drives: 10 Yaris Hb, 02 Camry 2.4
Originally Posted by remcafee View Post
adjusting the valves on the 1nzfe is not a diy task, you have to replace the entire lifter as they are numbered and have a spec, have to pull the camshafts, timing chain, tensioner, etc. your engine will be fine and i measured mibe on my 4th spark plug change at 220k miles and they were all in spec
Thank you for your answer. Wanted to update. I do not have an explanation on it, however the ticking went away completely. No noise at all from the engine. Runs very quiet. I did have a bad spark plug which changed out but this was after the noise went away. Just took it from Tampa to Orlando at 75mph and no issues at all.
Showtyme400 is offline   Reply With Quote
P2420 experience - "Evaporative Emission Pressure Switching Valve Stuck Off" snowblower DIY / Maintenance / Service 1 02-16-2025 03:54 PM
Valve adjustment bronsin DIY / Maintenance / Service 1 02-02-2021 05:55 PM
VALVE ADJUSTMENT INTERVAL jemmah DIY / Maintenance / Service 7 10-12-2016 10:13 AM
Valve Adjustment yarista General Yaris / Vitz Discussion 33 01-24-2014 11:00 AM
