![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
adjusting the valves on the 1nzfe is not a diy task, you have to replace the entire lifter as they are numbered and have a spec, have to pull the camshafts, timing chain, tensioner, etc. your engine will be fine and i measured mibe on my 4th spark plug change at 220k miles and they were all in spec
| P2420 experience - "Evaporative Emission Pressure Switching Valve Stuck Off" | snowblower | DIY / Maintenance / Service | 1 | 02-16-2025 03:54 PM |
| Valve adjustment | bronsin | DIY / Maintenance / Service | 1 | 02-02-2021 05:55 PM |
| VALVE ADJUSTMENT INTERVAL | jemmah | DIY / Maintenance / Service | 7 | 10-12-2016 10:13 AM |
| Valve Adjustment | yarista | General Yaris / Vitz Discussion | 33 | 01-24-2014 11:00 AM |
