Old 05-15-2007, 02:24 AM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by PetersRedYaris View Post
Oil from an oiled media air filter can coat the MAF sensor and cause a check engine light (CEL). This is generally caused by "over oiling" a cleanable/reusable filter. If it happens, you can easily clean the MAF by removing it and spraying it (very carefully) with MAF cleaner of electronic cleaner, and resetting the the CEL by disconnecting the battery for 10 minutes. It's no problem to fix. Oiled filters are superior to dry media filters and I would still recommend them.
also our CEL will turn off by it's self after so many key turns, after the problem has been solved... I found this out after trying to modify my intake
Old 05-15-2007, 02:28 AM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I didn't know that, that's cool.
PetersRedYaris is offline   Reply With Quote
Which Engine Air Filter to choose? YANGSTER Performance Modifications 16 09-29-2007 10:48 AM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
WR RAM AIR KIT dngz Performance Modifications 24 12-07-2006 08:33 PM
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
