Old 05-17-2007, 06:55 PM   #1
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
the only thing i am really don't understand that is if 5w-20 and 0w-20 is really good for our engine then why don't they listed in our manual but instead of 5w-30?
jamal1984 is offline   Reply With Quote
Old 05-17-2007, 07:04 PM   #2
jmjonesey
jmjonesey's Avatar
Drives: Red 2007 Yaris Sedan
Send a message via AIM to jmjonesey
What?! you didnt get the e-paper manual? all you have to do is take your manual to the dealership and get the new auto updating manual that keeps up with toyota's changes on-the-fly
jmjonesey is offline   Reply With Quote
Old 05-17-2007, 07:05 PM   #3
jamal1984
No i dind't receive nothing from them.
Old 05-17-2007, 08:54 PM   #4
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
TSB's are the most current info for our car supplied by toyota. sometimes the manufacturer may find something that is better for or car or fixes a common problem in our car. things are constantly updated due to common customer complaints etc. the TSB's are the most up to date information so they superceed any info in our owners manuals. the techs use them everyday to repair and service our cars. thus any info in the owners manual can be updated at any time. dealerships usually make the updates automatically when you bring your car in for service. sometimes you have to ask though...
Originally Posted by sambo42xa View Post
(2 post before me....) Read the TSB where it shows/says at the bottom, "oil recommended for these engines". If Your engine code falls in the list, then I do not see a problem using the 0-20 from what I understand after reading static808 TSB.
I will look at my "code" and if it is in the list I will try the 0-20 weight on my next oil change.
static808, I'm curious on the warranty part. There is nothing there. Does this mean NO WARRANTY if you use/change over to the 0-20??
Also, how did you obtain this TSB; something You found online; work for TOYOTA???
th
sambo42xa
Southern, NH
there is no warranty info b/c its only updating the grade of oil used during an oil change at the dealership. oil changes are not warranteed. if it were say a defective radio unit. then you would see warrantee information explaining that a new unit is under warrantee etc. hope this helps explain things a little.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 05-18-2007, 01:45 AM   #5
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
If the TSB say's 5w-20, use 5w-20. You guy's are willing to use 0w-20 in it's place because AMSoil doesn't have a 5w-20? Switch brands!!! Follow the CAR manufacturers recommendation, not the oils. I know it probably makes no difference, but neither does using AMSoil over Mobil 1. They are equally good, but one comes in the recommended weight.
PetersRedYaris is offline   Reply With Quote
Old 05-18-2007, 02:37 AM   #6
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
actually, im using the 0w-20 because of its added benefits. if i were to use mobil 1, which is very good oil i agree, i would also use their 0w-20. according to the mobil1 website:
"In addition to providing benefits for hybrid engines, Mobil 1 0W-20 is ideal for use in newer cars, trucks and SUVs manufactured by Honda, Toyota, Ford, Mercury and Chrysler, where a 5W-20 motor oil is recommended. Mobil 1 0W-20 not only meets the requirements of manufacturers recommending 5W-20, but it also provides superior low-temperature protection and the exceptional performance of a fully synthetic motor oil."
i misspoke, and saw that amsoil does indeed have a 5w-20, but their 0w-20 has much better test results and longer drain intervals. just trying to pamper my wifes car, since its a commuter car and the type of oil it gets is probably the only "modification" its ever going to see!! i am in NO way trying to peddle brands, i apologize if it sounded that way...
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline   Reply With Quote
Old 05-18-2007, 11:17 AM   #7
PetersRedYaris
Originally Posted by static808 View Post
...i misspoke, and saw that amsoil does indeed have a 5w-20...
Ok, I was under the impression that AMSoil did not come in a 5w-20. Also, for those looking to drop to the 5w-20 weight but don't use synthetic, Mobil makes a conventional 5w-20 oil called Clean 5000. I'm sure there are other brands as well.
Old 05-18-2007, 01:07 PM   #8
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
sambo42xa
sambo42xa is offline   Reply With Quote
TSB for steering pull? vst DIY / Maintenance / Service 12 06-09-2007 03:40 PM
Finally! KittenRD New YARIS Purchase Forum 6 01-01-2007 10:16 PM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 05:24 PM
finally found a good product to clean al plastic parts Adriaan Wash, Wax, Detailing, Exterior Repairs 4 12-01-2006 03:45 PM
It's finally here! Cathy New YARIS Purchase Forum 10 08-29-2006 11:08 AM
