#19 |
If the TSB say's 5w-20, use 5w-20. You guy's are willing to use 0w-20 in it's place because AMSoil doesn't have a 5w-20? Switch brands!!! Follow the CAR manufacturers recommendation, not the oils. I know it probably makes no difference, but neither does using AMSoil over Mobil 1. They are equally good, but one comes in the recommended weight.
#20 | |
Engineer/Artist/House-Dad
Drives: 2006 Toyota Sienna XLE Join Date: Aug 2006
"In addition to providing benefits for hybrid engines, Mobil 1 0W-20 is ideal for use in newer cars, trucks and SUVs manufactured by Honda, Toyota, Ford, Mercury and Chrysler, where a 5W-20 motor oil is recommended. Mobil 1 0W-20 not only meets the requirements of manufacturers recommending 5W-20, but it also provides superior low-temperature protection and the exceptional performance of a fully synthetic motor oil." i misspoke, and saw that amsoil does indeed have a 5w-20, but their 0w-20 has much better test results and longer drain intervals. just trying to pamper my wifes car, since its a commuter car and the type of oil it gets is probably the only "modification" its ever going to see!! i am in NO way trying to peddle brands, i apologize if it sounded that way... --B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels |
#21 |
Ok, I was under the impression that AMSoil did not come in a 5w-20. Also, for those looking to drop to the 5w-20 weight but don't use synthetic, Mobil makes a conventional 5w-20 oil called Clean 5000. I'm sure there are other brands as well.
#22 | |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
#23 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
I know a mechanic who has alldata. Perhaps I could get some info on the yaris this weekend? Anyone interested?
#24 |
![]() ![]() Drives: 07 YARIS Automatic/LiftBac/Red Join Date: Jan 2007
#25 |
![]() ![]() Drives: 2007 Yaris Hatch Join Date: Apr 2007
Just ordered one gallon plus two quarts and an oil filter. Amsoil 0-20 100% synthetic and amsoil oil filter for the Yaris. This weight oil is a new product for them (amsoil.com) . ABout $25 a gallon and $6.25 a quart and $14 for the filter. Currently running Castrol full synthetic (not really 100% synthetic, though) Also ordered the Fujimoto drain valve. Will change all at 5,000 miles. Car only has <2,000 now.
#26 |
![]() Drives: 2010 Yaris 3Dr LB Join Date: Oct 2009
Howdy, I just bought a 2010 Yaris and the owner's manual says to use 5W-30. As the TSB was 3 years ago now, I'd have thought that they'd update the owner's guide. Should we be using the 5W-30 or 5W-20?
#27 |
If you're manual states 5w-30 and it has a newer publication date than the TSB, then you should follow your manual.
#28 |
SIPNDEW
it doesnt seem like people here understand that the 1nzfe motor is NOT on the 0w20 list...it is on the 5w20 list. so from what i take on this tsb it is NOT ok to use 0w20 in the yaris.
#29 |
How long until people feel the need for 0W-0 oil? or even, -5w-0 oil?
#30 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Newhavenpatriot,
Bless you for taking the time to post this and enlighten us! I contacted Toyota about the same via phone (as well as my dealer) and they had no idea what I was talking about. This is what I always felt was intended by the bulletin, but up until now have had no proof. I made the decision to use 20 wt anyway, but it's nice to know it's ok! Thanks again! R2 |
#31 | |
Crazy Oil Sniffer
Your post above highlights the fact the SAE method of classifying oil viscosity is rediculous! It is antiquated and confusing to most-time for a revamp in my opinion. But yes thinner oils are coming! R2 |
#32 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Well, when they get here I think that'll be the day I opt for a German sedan w/ a nice turbo diesel that won't want oil the consistency of kerosene in their expensive motor.
#33 | |
![]() ![]() Drives: '07 Yaris, '12 GLI Join Date: May 2007
![]() Redline 0W10 oil Disclaimer: it's not recommended by Toyota, will void warranty, meant for racing, yadda yadda yadda...
#34 |
Crazy Oil Sniffer
I just found out about the Redline 0W-10 the other day-Royal Purple makes some too. Last I found it though it was like $14 a quart shipped. How much does the Redline go for? Thanks!
R2 |
#35 |
Hey R2. It goes for 12.95 a quart on their website before shipping. Interesting oil, not sure about engine longevity as it's application seems to be for racing engines
It's possible one day 10 weights will be specified...
#36 |
Crazy Oil Sniffer
Thanks Craig! When 0W-10 goes mainstream the price will come down :)
1st, Where's the love-thin is in! When the 20's went mainstream circa 2k many (including myself) cried foul. How dare they sacrifice longevity to help CAFE scores?! Guess what-they worked great! The Euros are lagging a little behind but are heading in this direction also. The TDI is running 5W-30 now! Here's a little light reading about viscosity : http://yarisworld.com/forums/showpos...=363921&post=7 Check out Dr Haas Lambo UOA on BITOG with 0W-20 and G Allen's 4.0 Jeep on 0W-10!
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it." -The Fitful One
| TSB for steering pull? | vst | DIY / Maintenance / Service | 12 | 06-09-2007 02:40 PM |
| Finally! | KittenRD | New YARIS Purchase Forum | 6 | 01-01-2007 09:16 PM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 04:24 PM |
| finally found a good product to clean al plastic parts | Adriaan | Wash, Wax, Detailing, Exterior Repairs | 4 | 12-01-2006 02:45 PM |
| It's finally here! | Cathy | New YARIS Purchase Forum | 10 | 08-29-2006 10:08 AM |
