Old 05-22-2007, 06:07 AM   #1
GuySmily
GuySmily's Avatar
Drives: 2005 Toyota MR2
This is a popular swap among us 1st gen MR2 guys. Then again, we already have 4age's in our cars..
At least for the Yaris the manual tranny is in the same family (c-series). You may not need to buy a new one.
Here's one example:
http://www.padandwheels.com/mr2/blac.../blacktop.html
GuySmily is offline   Reply With Quote
Old 05-22-2007, 03:24 PM   #2
DoriKnights
Drives: Rps13
Here's one example:
just found out @ scionlife.com that the tranny may just bolt right on.. .... since they have pretty much the same layout.. well the xa.. .. hmm more research...
DoriKnights is offline   Reply With Quote
Old 05-22-2007, 05:31 PM   #3
YarisGuy
Drives: 2006 Yaris
Very interesting! Look to see if you can find part numbers on the clutch and flywheel for the Yaris and MR2. If they match, you are one step closer.
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 05-22-2007, 06:37 PM   #4
weaponrcamry
Drives: Camry LE/Yaris Hatch 5spd
yes, we have discovered that the tranny from the 4age bolts right up to the yaris 1nz-fe if that's what you are talking about?? Maybe vice versa to. It wouldn't make since to put the yaris tranny onto the 4age because it is weaker IMO.. Just get the whole tranny that comes with the 4age(STRONGER). If you do this project please write a write up. The seems very interesting. I also here that the 2zz-fe tranny bolts up to the 1nz-fe also.
How much power do you want??? You can get about 220-230whp on the stock motor/tranny until you have to rebuild or so. The stock crank is good for around 9,000-9,500rpm.
Why don't you get this motor. http://cgi.ebay.com/ebaymotors/4AGE-...QQcmdZViewItem It has all the things that you need.
It would be better to get a whole front clip, but o well. The most difficult part of the swap is the wiring. Have fun...
|.....Overnight.........................| ||
|........Parts From Japan.............||'|";,__
|_..._...____________======||_|_|....,,]
weaponrcamry is offline   Reply With Quote
Old 05-22-2007, 07:13 PM   #5
RobStar86
Drives: 2013 Toyota Yaris LE Hatchback
The hardest part I can see about this swap is making sure you can get the axles and mounts and such to work. The wiring would be the easiest bit assuming you go with a stand-alone like megasquirt or something like that.
If you want just N/A power, go blacktop. If you want to go for boost later on, go with a silvertop, they are better suited to turbo.
Oh yeah, first post! Hi Everyone!
RobStar86 is offline   Reply With Quote
Old 05-22-2007, 07:59 PM   #6
DoriKnights
Drives: Rps13
yes a micro-tech will be used for the brains
with its awsome itb's and super high revs the 4ag has,a black top is what the block will be due to silvertops heavier internals and the black tops better airflow design around valves
Old 05-22-2007, 08:12 PM   #7
weaponrcamry
edited
Also the cv joints... Welcome to the forum..
Why the blacktop?? I would suspect the silver top because of the TVIS.
VVTi Managment Greddy Black Yaris Performance Modifications 29 08-12-2007 08:29 PM
4age 20v powered Yaris slothman86 General Yaris / Vitz Discussion 3 04-04-2007 08:31 AM
