Old 05-31-2007, 09:50 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
Ogredude,
Thank you for the DIY! It gave me the confidence to do this for myself.
I got all the parts at Home Depot, and more of them than you listed due to the lower valve of the Husky filters not closing worth a crap, but I came in at just under $20.
1) Small Husky fuel filter: $12
2) 2 3/8" pipe fittings: $4
3) Drip sprinkler: $1.50
4) Sprinkler goof plugs: $2
Total: $19.50
The drip sprinkler was the cheapest way to get a few millimeters of the 150 PSI drip hose that would fit the nipple on the bottom of the filter, and a goof plug caps it off. Other than that my install was identical to yours.
- Brian
Share the Road
Old 06-01-2007, 10:45 AM   #2
jlift
Drives: 2007 Yaris Hatch
Ogredude,
Total: $19.50
I just did this mod myself. What you say sounds interesting, but I have no clue what the drip hose and goof caps are. Are you able to kindly post a pic. or two? Thanks.!
jlift is offline   Reply With Quote
Old 11-23-2010, 06:39 AM   #3
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
On my Supra, I just vented the PCV to atmosphere. What's the point in spending money on a catch can?
Midnight Drifter is offline   Reply With Quote
Old 11-23-2010, 07:42 AM   #4
anexrx7
Drives: 08 MM HB
You let your Supra get all grimy from blow by? After an hour of running the RX7, that crap is everywhere when I have a leak on the vent hose.
anexrx7 is offline   Reply With Quote
Old 11-23-2010, 07:56 AM   #5
Midnight Drifter
Going Retro
Well I had a metal braided hose running from the vents down to the oil drain plug, I never had problems with leaks. I thought it looked kinda cool like that.
Friend of mine did the same thing with his Corolla SR5, still working great on his car.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
