DIY: LED side mirror installation
*WARNING*
This is at the moment just a partial DIY, I have not yet gone around to do the wiring, this will just show you how to remove the original covers, and put in the replacement ones. Tools Needed For cover removal and installation, a smallish screwdriver will do, but even just your car key can do the job. For the wiring, you will need some sort of portable soldering iron, but you could get away with just electrical tape. Step 1: Remove Mirror Panel This is quite easy, push the top part of the mirror, and hook your fingers under the bottom ledge. Pull the bottom toward you to undo the clips: ![]() After this, rotate the mirror pane as high as possible, and pull it toward you: ![]() Step 2: Remove cover This is a little tricky, as the cover is quite tight. I found it easier to concentrate on the two in the upper corner, using one hand with a screwdriver (or just your car key) to push the tab, and using your other hand to pull the front of the cover outward, so that the tabs do no re-engage. Then work your way around. There is one more tab at the bottom which is not easily accessible, but it comes undone when you pull the cover off. ![]() To pull the cover off, just pull it from the top and rotate it downward to disengage the last clip: ![]() And there you go, a naked wing mirror! At this point you would take the replacement cover and sort out the wiring. Step 3: Putting replacement cover on As you can see, the tabs on the replacement cover are an exact match: ![]() So, it's just a matter of aligning the cover, and pushing it until all the clips engage. I actually found some difficulty in doing this, especially with the bottom clip. Remember, take your time, make sure you have everything aligned, and push hard! Step 4: Put mirror panel back in Just the opposite of taking it out, you just hook in the top tabs, then press the bottom firmly until you hear the bottom tabs click. The result Firstly, keep in mind I chose black covers as an experiment to see how well they go with a different body color, I think it looks good, but I might just smoke the lens on it, it would look even better... ![]() ![]() ------------------------------------------------------------- Part 2 (a year and a half later) - Wiring So I finally got these wired up! I did it a lil' differently from the other DIYs that Violin and redyaris did, as I hooked up the indicator wires to the main relay/fuse box in the cabin (no need to drag cables into the engine bay) So for the first wiring part I'll just steal pictures from others ![]() Step 1: Remove the door panels This is actually a copy of FEINT's DIY (http://www.yarisworld.com/forums/showthread.php?t=15011) Starting on the left hand door. Remove the armrest piece. It just pops upwards. ![]() This is just another illustration of the same piece that should pop up. On the other end of the door, use a small screwdriver to pop open a cover as shown in the photo. ![]() This is what it will look like after taking off the piece. ![]() Proceed to remove the power window switch panel and the other panel illustrated in the photo. These should both pop up as well. No tools required, just use your hands. ![]() Remove the connector for the power window switch by pressing the tab and pulling. ![]() This is what it looks like after removal of the above 2 pieces. ![]() + screwdriver required. Remove the 4 screws as shown in the photo. ![]() To remove the door card, I pulled anywhere along the bottom of the door. It will come apart as shown. ![]() It might require quite a yank to get it to come off. After it has seperated from the door, push the door card UPWARDS, it should come free after that. Remove the door / lock wires from the latch. These are where all the little grommets are located in order for you to re-attach them to the door card for installation. ***There is one more behind the hand.***. ![]() Step 2: Taking apart the mirror base Thanks to redyaris for these pics Basically, there are 3 nuts holding the mirror base to the door: You can get those off with a 10mm socket wrench, but be careful not to drop them into the door! The result: At this point I do not really have pictures, but here's what you need to do: 1) remove the mirror piece from the assembly if you had put it back (the very first step in this DIY) 2) Remove the 3 torx screws on the bottom of the mirror assembly, you need a T20 size driver for this: mirror.jpg 3) Once you have this all apart, it is easier to snake the wires through the narrow passageway between the mirror assembly and the inside of the door. ALTERNATIVE! This is from Violin's DIY, but I could not get this to work (I think my power mirror wires are shorter: If you have power mirrors, use the existing wire to help you fish the new wires through. Pull the wire back toward the mirror all the way so the power mirror connector bumps tight: ![]() Tape your LED wires to this wire: ![]() Pull everything through: ![]() Unwrap the tape and you're in business: ![]() Step 3: Power source Now we must run these cables to the inside of the car. If you look at your door jamb there is a corrugated rubber tube already there, housing your speaker cables and power lock/window/mirror wires if your car has those. So once again thanks to Violin for the DIY/pics: I took my speakers out and ran the wires down through the door ![]() and fed it through the boot into the cabin ![]() Now this is the main difference with the other DIYs, I wired the mirror signals to the relay/fuse box in the cabin. US guys, you will find this box by removing the small rectangular panel below and to the left of your steering column (thanks LtNoogie for the pic): ![]() People with the steering wheel on the right, just remove your lower passenger glovebox and you have much easier access ![]() Here are the wires we need to tap: In my own car these already had some extra wires tapped to them, not quite sure what they are for :DSC_1306.JPG So, thankfully these mirror covers come with long wires, as for the other door you need to run the cables under your dash. One clean way to do this is to remove the dash and lay out the cable nicely, but I just passed it through whatever holes I could find on the way across and taped it in place so it does not get stuck in my feet when I drive ![]() Anyway the next step is thus to splice/crimp the wires. The older version of these mirror covers came with two sets of lights. One orange for the turn signals (red wire), and one white to be linked to the parking lamps (gray wire). I did not hook up the gray wires, but there'll also be a similar cable in that relay box that you can tap into. Once I figure out which one, I will add it here. And, I believe the newer versions of these covers don't even have those white lights, just all orange turn signals, and thus two wires only. So, just crimp the red wires from the covers onto the appropriate wire on the plug in the relay box. Mine are attached to those extra wires I already had, easier to reach! DSC_1307.JPG Then attach the black wires to a grounding point (not shown, just look for a big bolt attached to the car frame with a wire attached to it. Loosen it, wrap the stripped ends of your black wires around the stem, and tighten). Or, you can use another cable crimp to attach the wires to the ground wire there. Best thing to do now is to test everything works, before you close it all up.. and you're done!
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... Last edited by eTiMaGo; 04-04-2009 at 06:01 AM. |
I can't wait!
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
How do they match against the existing black? The Pics don't show how much gloss they have to the flat black that is there. I'm leaning more towards them. Thanks for the DIY!!
well, the mirror is a lot glossier, and has the metallic paint look, so it's not a match at all, but it does not look bad in person. It's night time here, so I'll try and take a better closeup pic tomorrow.
I am tempted to respray them in matt black and smoke the light lenses...
![]() ![]() ![]() Drives: 07 Sedan - 5 Speed Manual Join Date: May 2006
Looks good. Keep up the good work eTiMaGo
I hope that this has not been covered already, but is there a chance to get these unpainted?
#8 | |
Yaris Sedan 2007
Drives: toyota yaris sedan 2007 Join Date: Mar 2007
wow, i want that!
does it fit the sedan? |
Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
I think I'm getting mine first, so I'll post up a wiring DIY once I get it done.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
Q(','Q)
Hope the black and silver look good too!
Think you could send me a photoshop version of your car but in silver Thomas? IMO I find the red sideview better then the black one Tom. Something about your car being so bright makes the red look good. Maybe it's the lighter color theme or something. |
well, here's a closeup picture.
Something I didn't notice before, these ase sensibly thicker than the original covers, but it's not bad looking
It could grow on me, Violin hope you get them soon, DIY would be great!!
Shiny Chromey Coolness
Drives: 2007 Toyota Yaris Liftback Join Date: Feb 2007
Please Etimago please finish this DIY for the wiring part.
Btw you make me sick with your 5 door dammit. It looks so good.
Bringin the Bling to Yarisworld |
Green is good
Oh.... very good
I just gave up my job for a long time as i afraid will break my mirror thank you.... eTiMaGo you are a great teacher |
hahaha a teacher who has only taught half a lesson, not that great
Green is good
Great instructions so far... Thanks for sharing your work with us.
BTW, black mirrors on red look kind of interesting... certainly make you take a second look and wonder for a few seconds... what's different about that Yaris? |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| DIY: Yaris LB Halo Led Projector Headlights | goku87 | DIY / Maintenance / Service | 37 | 11-15-2013 06:23 AM |
| DIY for Low Cost Dim Light in the light LED | tang | DIY / Maintenance / Service | 0 | 03-08-2009 10:58 PM |
