Old 07-01-2007, 12:33 PM   #6
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Orange peel is a certain kind of texture that may develop on painted surfaces.
Gloss paint sprayed on a smooth surface (such as the body of a car) should also dry into a smooth surface. However, various factors can cause it to dry into a bumpy surface resembling the texture of an orange peel. The orange peel phenomenon can then be smoothed out with ultra-fine sandpaper, but it can be prevented altogether by changing the painting technique or the materials used. Orange peel is typically the result of improper painting technique, and is caused by the quick evaporation of thinner, incorrect spray gun setup (e.g., low air pressure or incorrect nozzle), spraying the paint at an angle other than perpendicular, or applying excessive paint.
In some situations, such as interior house paint, the orange peel texture is desirable. In this case, a texture paint is generally applied with a spray gun. The texture is then painted over with the appropriate color.
....hum, interesting, no can't say that I have this problem but I gave my car a good once over before I bought it
SPONSORED BY
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
