#34 | |
If you're running ET40mm (and 205/50/15's), you should be flush up front... is that right? Take a level and a mm ruler and see how many mm's will bring the rears out to where you'd like them (to match the fronts). Then look for the size spacers you want... they're available in a wide range of mm widths. |
| Torquing those Lug Nuts... | Doc Zaius | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-13-2007 12:19 PM |
| Cheap Lug Nuts? | KwonSau | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-06-2007 12:51 AM |
| How to remove the Nut on the top of the shock tower | hystria | DIY / Maintenance / Service | 29 | 12-08-2006 09:30 PM |
| 5 lug adapter? | funkstrong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 10-21-2006 04:49 PM |
| Lug Nuts for Konig Helium Wheels? | OK Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-19-2006 05:58 PM |
