![]() Drives: Yaris Join Date: Jul 2007
FWIW, I work at a Toyota Dealership and even though nearly all the cars reccomend 5W-20, the service department only uses 5W-30.
![]() Drives: 2007 Red Yaris LB MT Join Date: Mar 2007
Then u should know that their is a tsb stating it is safe to use 5-20 in any toyota veh using 5-30, the dealership i work at only stocks 5-20 in bulk and just keep quarts of other weights for older veh. personally i use amsoil 5-20
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Some dealerships will use 5w30 over 5w20 because generally its cheaper in bulk. I have lubricants training and used to sell lubricants (9 years worth) and now run a performance tuner shop inside a Toyota dealership. I personally run a light viscosity 5w30. .02 mpg is not worth less life out of an engine.
#4 | |
Engineer/Artist/House-Dad
Drives: 2006 Toyota Sienna XLE Join Date: Aug 2006
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels |
#5 | |
Acording to oil manufacturers to call an oil SAE (Society of Automotive Engineers) a 30 weight it must be betwwen 9.3 to 12.5 centistokes at 100 celcius. I use an 5w30 thats near 9.3 at 100c. Im making a compromise between what Toyota originally spec's for our engines and what they now say as people want more mileage and they sell more fuel sucking Tundras. A 20 weight on the other hand is any oil between 5.6 to 9.3 centistokes at 100c. why would you take the chance and rely on tha additives to prevent wear like in a 5w20 when in a 5w30 you will rely on hydrodynamic lubrication( the oil itself).
#6 | |
--B
Thanks. Is it Amsoil 5w20 thats 9 centistokes at 100c? if so go for it , its close enough, to what your happy with. The last time a ran Amsoil a few years back, their 5w30 was more like 12 centistokes? I cant remember which one it was! If you live in a warm climate I would go with a heavy weight 5w30. you won't see much milege improvement with only a 1 or 2 centistoke reduction, so go with the cheaper or more readily available one. I live in Canada and its not that hot so I feel safe running a lighter weight. If I lived in Texas for example I would find a 5w30 on the heavier side.
