#19 |
Hi!
#20 |
on a similar note, doesn't Motegi wheels sell some sets of wheels that are meant to look staggered (i.e. the rear wheels have deeper lips, but are actually the same offset), I saw an ad for those in a magazine, sounds like an interesting concept!
#21 |
der Zeck
I like the comment above of the rear spacers, so that you can use the same wheels, and continue to rotate, and sell the wheels at a later time if you so wish
Hmm.... 205/40R17 on the front with a +42 215/40R17 on the rear with a +42 and 10 mm spacer ? any comments on the above setup?
#22 | |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
SPONSORED BY
#23 |
der Zeck
I am going to tuck tire on the rear
so I may go with the 5 mm spacer with the 215/40 then on the rearsuspension TBA
#24 |
Lonesome Cowboy
cool, I haven't really measured myself so you may be able to go more
SPONSORED BY
#25 |
This Vitz/Yaris is running 17x7's; FR ET42; RR ET35; 205/40/17's; Tein lowered.
#26 |
Lonesome Cowboy
wow I wouldn't want the rear pushed out any more than that! 5mm spacers it is. if I decide to push the rears out at all. Thanks for that picture that is a good shot. +30 would seriously poke and +25 would be throwing debris
SPONSORED BY
#27 |
![]() ![]() Drives: 07 RS Join Date: Jun 2007
This was done very well (Kudo's to Jooky).... But is there a performance/functional downside to staggering??
Honda to Toyota... lets see how this plays out
#28 |
Lonesome Cowboy
would create some understeer however you will decrease some oversteer so it depends on what you like, to me it would be looks over functionality but this isn't extreme so you may not feel much difference at all
when I think really staggered I think of the rear wheels seriously poking from the car, this kind of staggering is just giving the car visual balance for the most part off subject-I prefer the look of the car on 15's though myself
SPONSORED BY
#29 |
well im thinkin' 16 CE28's come in 16x7 in offsets +25, +33, +42, +48 and 4 x 100 bolt pattern
16x7 ET + 33 front and 16x7 ET +42 rear on a 1.25 inch drop or since its not to low just got with 16x7 ET +42 all around i know Largeorangefront's running Konig Heliums 16x7 ET 40 they look nice and he's dropped a lot lower
#30 | |
1. ET42 all 'round would be fine. 2. ET42's and 5-7mm hubcentric spacers in the rear. 3. FR, ET42; RR, ET33. |
#31 |
with my car not being as low...
205/50/16 or 205/50/195 cause i was thinkin 195 like Cali_yaris
#32 | |
Initially, he had a rubbing problem running 205/50's, but solved it by switching to the 195/50's. I'm guessing it wasn't a height issue, but a width issue that caused the rubbing. Check this out with him. If you plan to run ET42's, you should be fine with 205's, provided you haven't really dumped your car. |
#33 |
here she is... not to low 30 MM which is 1.25 inches
#34 |
der Zeck
by the weekend I plan on having my yaris down about 3 inches or so on my 205/40R17s
#35 |
![]() ![]() Drives: '07 3 Door Yaris of Doom! Join Date: Dec 2006
The rear wheels/tires of the Yaris are there to keep the ass end from dragging on the ground. The rear tires don't really need to be any wider than stock. Wider wheels/tires in the rear will cost you at the pump while slowing the car down. And I'd also be giving out those crusty looks to the homie thinking a nice 911 stagger looks good on a Yaris. My vote would be for proper offset and fitment for the front and rear while keeping the same size wheels and tire. The cheap way would be spacers, as has been stated previously, you would retain the ability to easily rotate the wheels/tires if utilizing a simple 5mm spacer. For those with bigger budgets, just get the staggered offsets wheels.
Now just an FYI... Performance wise, on a Yaris you would want to push the front wheels as far out as possible and have the widest tires and rims that will fit. You will want the rear track to be narrower than the front. This will help the car "rotate" when driving aggressively or on track.
#36 | |
Thanx... like i stated before... i dont plan on going staggered.... i just wanted to ask fo rthe sake of learning....
thanx to all those who responded Quote:
