![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
TRD Thermostat
TRD Japan JDM part
*Cools engine quickly *3 gaskets; 1 rubber, 2 paper *For performance driving * TRD Thermostat opens @ 160 degrees Fahrenheit = ~71degrees Celsius Factory Toyota thermostat opens @ approx 180 degrees Fahrenheit = ~82 degrees Celsius http://cgi.ebay.com/ebaymotors/ws/eB...DME:L:RTQ:US:1 will this work for our engine... or no i have a US 2007 yaris liftback 1.5l
"It hurts more when its wet" |
Down With the Sickness
no because its for the 1st gen yaris, our code is ncp91
Strength - Determination - Merciless - Forever |
dam ok thanks
Holy seventy-four dollar thermostat...
I like the idea of it running cooler but $74?...
I would do an aluminum radiator and a big 'ol fan before a thermostat.
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Wanna run cooler, add redline waterwetter and/or run only 30% coolant to70% water. Remeber to go back to 50/50 coolant in winter if you dont want to crack your block in freezing temps! Water does a better job of heat transfer so your engine runs cooler only risk is your boiling point is also lowered! cheers!
From what Ive always understood its best to keep the engine within a narrow temp operating range. Older engines worked great with 180 degree thermostats because it kept them from detonating. Modern engines are now running into the 200+ degree range for emissions and economy reasons. If you drop the temp of our cars from 190 +/- to 160 wont that throw our ECU for a loop?
http://www.cardomain.com/ride/2336679 |
TRIM HUNTER
from what ive found out(i can't get part number now im on vacation) the trd thermostat that fits the supra will work on our cars as well as others. search the trd japan website and you'll find the info i just said.....
#9 | |
Hi!
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
part number is 16340-sp020 and thats from trd japan thanks to google tranlate...
http://www.carid.com/toyota-accessories/ site has a FEW interesting yaris items..... |
| TRD OR Eibach...i'm confused... | hoahmaru | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 39 | 11-07-2008 08:25 PM |
| Fs: New Trd Stickers & Emblems !!!!! located in So cal | Trd86 | Items for Sale by private party | 13 | 06-25-2007 04:49 PM |
| TRD Parts | MC-BPT | Sponsors Classifieds Area | 9 | 06-23-2007 10:51 AM |
| TRD sport seats in a sedan/belta | platypus | Cosmetic Modifications (Exterior/Interior) | 17 | 01-05-2007 08:43 PM |
| Toyota's Yaris TRD | VitzBoy | General Yaris / Vitz Discussion | 10 | 07-24-2006 08:10 PM |
