Old 07-31-2007, 08:08 PM   #19
joey1320
joey1320's Avatar
Drives: Yaris LB
Originally Posted by Turbo&Auto View Post
175whp is VERY reasonable on the stock block. With that small of a turbo you can run 14-17psi and it wont hurt the motor. PSI doesnt hurt the motor, its just a measure of resistance at the TB. ;)
300whp is prolly the tops for an average build on this motor. A log mani will support 350ish to the wheels. You wont need a large hot side since there is just no displacement or high revving. Smaller hot side with a decent sized compressor will work nice for response and top end :)
i'm sorry but how does boost doesn't hurt a motor? if the internals are too weak to support the explosion/extra volume in the cylinders they will bend/break.
also you are correct about the bigger turbine not being needed. for the full built engine i'm thinking of using a Garrett GT2560R or something similar to that turbo. i have seen in person what it can do on a 1.5l Honda engine and i believe i'll get the results i want.(sorry about the t3/t4 comment earlier...)
joey1320 is offline   Reply With Quote
Old 07-31-2007, 08:28 PM   #20
johnnyfive
johnnyfive's Avatar
Originally Posted by joey1320 View Post
i'm sorry but how does boost doesn't hurt a motor? if the internals are too weak to support the explosion in the cylinders they will bend/break.
i belive all that he was saying was that the psi wasnt the thing that was going to hurt it...
johnnyfive is offline   Reply With Quote
Old 07-31-2007, 08:49 PM   #21
joey1320
joey1320's Avatar
Drives: Yaris LB
as opposed to???
Old 07-31-2007, 11:03 PM   #22
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
I do mean to a point. You cant go out and run 30psi and expect it to not explode. BUT within reason, 1bar(14.7psi) or a lil over is fine with that size turbo.
You will want to check the compressor map and make sure it isnt going to choke up that high. Smaller turbo tend to like the 15-18psi range though so 15 shouldnt be an issue with a good tune. I prolly wouldnt run it hard on that setting everyday, but when tracking it, it will be no prob.
Turbo&Auto is offline   Reply With Quote
Old 08-01-2007, 02:16 AM   #23
leasaunce
Drives: Toyota Yaris
WOW DUDE!!! You'll l definitely be my GURU when I get my Yaris!
leasaunce is offline   Reply With Quote
Old 08-01-2007, 06:38 AM   #24
lifthard1
Drives: Black LB
Yeah T&A knows his stuff
lifthard1 is offline   Reply With Quote
Old 08-01-2007, 07:31 AM   #25
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
Thank you, I try to offer legit info :)
Old 08-01-2007, 10:47 AM   #26
hey, everyone loves a little T&A
Old 08-03-2007, 04:29 AM   #27
g0nthedin0
Grip Driving
g0nthedin0's Avatar
Drives: White Liftback Yaris
Send a message via AIM to g0nthedin0 Send a message via MSN to g0nthedin0
damn 1 up son! hahah Give us Dyno Results when you're done, i'm sure you'll be running crazy !
g0nthedin0 is offline   Reply With Quote
TURBO DIY... forpinks Forced Induction Forum 33 09-06-2007 02:03 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
Toyota Vios Turbo elsteverino889 Forced Induction Forum 4 05-03-2007 11:54 AM
NCP 91 RS 1500 TRD Turbo ????? ramishrrr General Yaris / Vitz Discussion 3 01-15-2007 04:51 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
