Old 08-02-2007, 09:07 AM   #19
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by GabL View Post
Why is it worthless?
Uh, maybe because our US Spec cars dont have a way of connecting to this feature on the housing!
Old 08-02-2007, 09:08 AM   #20
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
Originally Posted by GuySmily View Post
Looking at the pictures again, I have a feeling you're going to have to do some custom wiring. I thought when you said separate high beam you meant like the kits where it's integrated into the same bulb as the HID..
You may just have to follow the last diagram I posted in the other thread after all... Here it is for reference:
[img][/img]
You're gonna have to bust out the multimeter and figure out which wires lead to the ballasts, and which lead to the high beams.
I'm checking the manual for info on the connectors
edit- Hahaha... The connector list is 10 pages long... Uh.. Gotta find a Taiwan service manual...
Can you take a pic of the ballast plug for me? I haven't seen pics of their D4S/D4R ballast before.. It may be the same as their D2S. This would keep you from having to chop anything else up if you can find the plug..
So I cannot just re-hook the wires to the right wire on the headlight module to make it work? Hence there should be a wire for DRL, low beam, high beam and parking light on the stock setup?
Here is the picture of the plug...
GabL is offline   Reply With Quote
Old 08-02-2007, 09:10 AM   #21
GabL
I want JDM bumpers!
GabL's Avatar
And here is what it looks like inside...
Old 08-02-2007, 11:02 AM   #22
GabL
I want JDM bumpers!
GabL's Avatar
Originally Posted by vasilios View Post
can i ask from whom/where did you buy those, and how much did they set you back?
From Taiwan, yahoo auction.
It costed me about $650 CDN + shipping.
Old 08-02-2007, 12:01 PM   #23
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
outch
OxyG3nE is offline   Reply With Quote
Old 08-02-2007, 12:07 PM   #24
Chris07LB
Chris07LB's Avatar
$650 is not bad at all... I was under the impression that HID and reflectors = not a good idea... I'd like to see these installed and turned on. : )
These headlights are designed for factory HIDs.
Not every headlight housing has a projector lens from the factory for HIDs. Prius, Navigator, QX56 are just a few examples of factory installed HIDs, without a projector lens.
Old 08-02-2007, 12:26 PM   #25
GabL
I want JDM bumpers!
GabL's Avatar
Same as my '00 TL
Old 08-02-2007, 12:43 PM   #26
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
projectors > HID reflectors :)
but great score on some nice headlights. Hopefully the beam pattern is correct, you wouldn't want the light to shoot to the opposing lane instead of the right side.
As for your connection issues, you CAN just hook them up to your stock harness, BUT its recommended that for the HID's you build a relay harness which will feed power straight from the battery. The reason is because HID's tend to draw a high amount of current during its initial startup and then drop to a low level after the bulb has been ignited, and over time that huge surge in startup current might be destroying something that wasn't designed to handle it.
It's a safety precaution, and a recommended one at that. I've seen people with other cars that have had connectors and wires fry.
taKuto is offline   Reply With Quote
Old 08-02-2007, 02:09 PM   #27
GabL
I want JDM bumpers!
GabL's Avatar
Thanks for the tips, another member GuySmily also pointed that out. I will try to upgrade the wires if it is possible to do so.
Old 08-02-2007, 02:52 PM   #28
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
nice headlights. i wonder if the beam pattern sucks like mine. pics of the beam pattern please! tia
reznunt is offline   Reply With Quote
Old 08-02-2007, 03:03 PM   #29
GabL
I want JDM bumpers!
GabL's Avatar
It shouldn't be bad, at least no glazing I would say, as you can see the reflector patterns in the housing are totally different from the ones we have in North America.
Old 08-02-2007, 04:35 PM   #30
GabL
I want JDM bumpers!
GabL's Avatar
GuySmily,
Your diagram shows the connection for H4 HID bulb, will it work with the headlight unit? Can I not just match up the wires (high beam/DRL to halegon, parking to parking, and low beam to HID)?
Old 08-02-2007, 04:43 PM   #31
Chris07LB
Chris07LB's Avatar
Sorry, wrong again.
Your stock housing for example is a reflector, where as a projector lens directs the beam of light. The bulbs cover, the diffuser, in your stock setup, redirects the light back into the housing, then the housing "reflects" the light foward.
re·flec·tor (rĭ-flĕk'tər)
n.
Something, such as a surface, that reflects.
pro·jec·tor (prə-jĕk'tər)
n.
A device for projecting a beam of light
GabL sorry for the post jack..
Old 08-02-2007, 05:00 PM   #32
GabL
I want JDM bumpers!
GabL's Avatar
Thanks for the bump Chris07LB! hahaha!
Old 08-02-2007, 05:06 PM   #33
Chris07LB
Chris07LB's Avatar
Old 08-02-2007, 06:35 PM   #34
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
what do you mean by 'wrong again'? If I'm wrong for posting an opinion, just say so, you don't have to make me look like an idiot.
GabL, what you will want to do is make a separate wiring harness for the HID's. You will use the low-beam, and the high-beam as the trigger wires, but the high-beam wire will also go to the high-beam bulb.
Old 08-02-2007, 06:51 PM   #35
Chris07LB
Chris07LB's Avatar
Corrected your wrong information given ("projectors are HID reflectors"), not making you look like an idiot.
This is a site to learn and share information. So when you post something wrong, that someone may take for the correct way, expect someone to reply to your comment(s).
Old 08-02-2007, 07:56 PM   #36
uncleyaris
Tiawan drives the same as north america, you'd be OK GAb
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 08:55 PM
Southeastern Power Package with Alloy wheels? Where is my Yaris? New YARIS Purchase Forum 0 03-23-2007 08:40 AM
convenience vs. power package jeff_o General Yaris / Vitz Discussion 25 10-17-2006 11:04 AM
Is concenience package and power package the same thing on liftback ? YarisBlazer General Yaris / Vitz Discussion 4 07-22-2006 12:58 AM
Waiting for the Taiwan Yaris heybai General Yaris / Vitz Discussion 13 03-12-2006 08:26 AM
