Old 08-06-2007, 05:29 PM   #10
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
(largeorangefont:The don't do anything or improve braking performance at all.)
well, they disipate heat better, so they do something. you ever heard the expression "brake fade"? thats when the pads and rotors get too hot and stop gripping as well. this ussually only happens if you are doing alot of downhill or aggresive driving. Also, if they are good pads, you will notice better performance, as aftermarket pads can often grip better.
now, the downside to slotted and drilled rotors (especially slotted), is that they tend to crack much easier than regular rotors. so, do they disipate heat better and look "cooler"? heck yeah! do they last as long as conventional rotors? heck no!
Feeler: Brembo Max brake rotors eTiMaGo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 08-07-2007 08:05 PM
Slotted Brake Rotors Violin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 04-21-2007 11:16 PM
Cross Drilled Rotors for yaris Adriaan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-16-2007 03:27 PM
Performance Brake Rotors YamilR Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-22-2006 05:31 PM
