Old 07-16-2006, 10:57 PM   #1
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
Toyota AUX plug w/ aftermarket radio?
i've got an '07 liftback w/convenience pkg. here in the states so i have the factory AUX input for an ipod or other type of device... i loved having that feature right were it is at.... well, i just changed out my stock stereo to a nice premier pioneer head unit i had in my other car... i want to be able to use the stock aux jack with my aftermarket radio... is there any kind of adapter to go from the aux plug in the dash to say an rca plug? i know how to go the other way and add aux input to the stock radio, but i want to be able to just use the stock plug outlet w. my aftermarket radio that already has rca inputs... anyone?
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 07-17-2006, 12:02 AM   #2
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
how old is your pioneer H/U? some of them now come with aux inputs built right into them. Or are you just looking to reuse the one thats there?
mikeukrainetz is offline   Reply With Quote
Old 07-17-2006, 12:06 AM   #3
mikeukrainetz
I just found the other post with pics of the stock aux input, ive never seen that before.
Old 07-17-2006, 12:18 AM   #4
eight_heads
well the stock aux goes to a plug that plugs into the cd changer spot on the back of the radio... i want to go from that plug to rca or something... get it? i have rca inputs on my pioneer hu, but i want to keep the stock aux jack
'07 Yaris Liftback
Old 07-17-2006, 01:15 AM   #5
ben dover
Drives: sw20 turbo
why not cut the OEM plug and add (solder) some RCA.? and do u have pic of your radio install. thanks
ben dover is offline   Reply With Quote
Old 07-17-2006, 01:29 AM   #6
eight_heads
well i'm not sure what is what on the plug... i probuably will use my multimeter and figure out what is what, but i would rather just add an adapter... i don't have any pics up yet but i've got a Pioneer DEH-750MP and i used the Best(brand name through AAMP...aka Stinger) wiring harness and dash kit(used the factory mount with just the trim and pocket from the dash kit... fit great... and i will be taking some pics soon...
'07 Yaris Liftback
Old 07-17-2006, 02:03 AM   #7
ben dover
Drives: sw20 turbo
good luck finding an adapter. if you do find one let me know cause i my do the same thing in the distant future.
Old 07-17-2006, 04:11 PM   #8
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
A picture would definately help...but let me ask...are you saying that there is a male mini-jack end that plugs into the "headunit" and then of course the jack that you connect to in the cabin is the female? If that is the case there is this:
http://cgi.ebay.com/TWO-3-5mm-Female...05254848QQrdZ1
or if you can't find it there I have purchased adapters from these guys before with good results:
http://www.audiogear.com/Audio-Adapters-Miniplug.html
Hope that helps.
Old 07-17-2006, 06:16 PM   #9
eight_heads
no, it's not a mini-jack on the other end... that's what i want... or rca... anyway, here are some pics of the back of the stock radio with the plug area i'm talking about... and also, some pics of the finished install
'07 Yaris Liftback
Old 07-17-2006, 06:31 PM   #10
fnkngrv
fnkngrv's Avatar
great pics....
I just called Car Toys and a couple other places and they are stating that they do not believe that anyone will be making a "conversion" adapter for that cable due to the lack of quantity they would sell. They suggested purchasing a female min-jack to RCA male that is long enough and mounting it in place of the factory cable.
Old 07-17-2006, 07:34 PM   #11
eight_heads
hmm, i will probuably just end up figuring out the pinout for the plug and soldering in a jack cable....
'07 Yaris Liftback
Old 07-18-2006, 12:12 AM   #12
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
Somebody already did figure out I believe. In one of the aftermarket units install, somebody installed a jack and used the stock wiring.
TrancosRt is offline   Reply With Quote
Old 07-18-2006, 12:54 AM   #13
eight_heads
no, i belive someone just mounted a mini-jack to the spot under the dash, they didn't use the stock aux input spot
here's the pics of echo_hrs' input...
thanks echo_hrs for the pics, hope you don't mind me using them....
anyway, this is not what i want to do.... i want to use the stock plug....since i already have it and like the location
'07 Yaris Liftback
Old 07-18-2006, 02:05 PM   #14
TrancosRt
TrancosRt's Avatar
Checkhttp://yarisworld.com/forums/showthr...ghlight=wiring post for wiring instructions. I think that the #5 gives the wiring instructions.
It's not exactly what you asked for, but should give you some pointers on where to begin...
Old 07-19-2006, 12:42 AM   #15
eight_heads
thanks for the link... that helped me out alot on what i wanted to know... i went to radioshack and got a mini-jack to rca cable adapter(to use the rca part).... i stripped the wires down and connected the two grounds together and put a spade connector on them... then i put seperate spade connectors for the left channel and the right channel.... then i added t-tap connectors(it's a no-strip, no solder connector for wiring that allows tou to connect to that wire by slipping the spade connector into it) to the gray, green, and red(the one next to the gray) wires.... they wires are as follows:
1. green = left channel
2. gray = ground
3. red(next to grey) = right channel
so by using the t-taps i did not have to cut off or damage in any way the factory plug... i then connected my new rca adapter to my h/u and it works great... now i can use the factory aux plug location as the aux source for my pioneer h/u.... instead of waiting for a brand made adapter i just made my own... it was dark when i did this so i didn't take any pictures... i will try to next time i have the radio pulled out
'07 Yaris Liftback
Old 07-19-2006, 12:13 PM   #16
TrancosRt
TrancosRt's Avatar
Glad to help out :D
I knew I've seen the wiring somewhere!
Old 08-03-2006, 01:26 AM   #17
Kiteless
Kiteless's Avatar
Drives: US 2007 Yaris Liftback 5MT
Oh that modded Echo looks great. That is exactly what I want to do with mine, but I want to add an integrated A/B audio selector switch. One of these weekends when I finally get my hands on a dash kit I am just going to do it all at once. It will be time to bust out the Dremel and make a few trips to Radio Shack.
- Kiteless
Kiteless is offline   Reply With Quote
Old 08-04-2006, 01:01 AM   #18
eight_heads
well after using this setup for a couple of weeks it is working out great!sounds great and i still have my stock plug and am using my stock jack so everything could be put back the way it was in like 5 minutes... i will be taking my radio out for a few minutes sometime soon and will take some pictures of the setup
'07 Yaris Liftback
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 09:01 PM
Two Millionth Toyota Sold in UK VitzBoy General Yaris / Vitz Discussion 0 03-06-2006 04:52 PM
