Old 08-21-2007, 05:47 PM   #1
NimbleYarisOwner
Yaris my baby
Drives: Yaris Hatchback 2007
Regenerative braking?
Really thats where u loose allot of energy.
If you have a Manual you can brake by shifting into gear
which will turn the engine and the serpentine belt.
Has anybody considered taking the AC compressor and completey
making it serve a different purpose. It would compress air into a chamber.
During acceleration from a stop, you would run the aircompressor in reverse.
I dont think an AC compressor can run in reverse can it?
I never use the ACcompressor anyway for its intended function.
Or take the AC compressor out, install an electric generator which will charge a battery when activated by the brake pedal, and act as a motor during acceleration from standstill.
NimbleYarisOwner is offline   Reply With Quote
Old 08-21-2007, 05:59 PM   #2
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
If you're really that intersted in modifying the AC, I'd simply unhook it so it taxes the engine less, and then remove the compressor for a weight savings.
Old 08-21-2007, 06:06 PM   #3
NimbleYarisOwner
Yaris my baby
What do u mean unplugging the the AC?, doesn't that AC engage with somekind electrically activated clutch when u press the AC button.
Old 08-21-2007, 06:33 PM   #4
Thirty-Nine
Well, the AC is run off of the engine using an accessory belt. By disconneting the belt, you are now rendering the AC useless. No belt -- no means for the compressor to turn -- less drag on the engine. Remove the 15 lb. (if that) compressor from the car. Frankly, I bet you wouldn't see a measureable increase in fuel economy, though. It's probably not worth it.
Old 08-22-2007, 09:32 AM   #5
NimbleYarisOwner
Yaris my baby
Does the yaris have one belt running all acceseries, i.e. a serpentine belt?
OK you have answered the question, its an accesory belt.
I am very eager to take a hacksaw to this Yaris.
Old 08-22-2007, 10:47 AM   #6
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
Can't say that I follow the logic there, my friend
Sounds eerily like something from a B horror flick
YarisTom73 is offline   Reply With Quote
Old 08-22-2007, 06:18 PM   #7
NimbleYarisOwner
Yaris my baby
Assuming you have a manual transmission,
you could use somekind of energy capture device to store braking energy.
during decel, you leave it in gear longer.
this may be possible with an airmotor.
During braking you activate a valve which controls an air motor turning it into a compressor. During accel, it runs as a motor.
An air motor attached to the engine via a belt is used to compress air into a tank. the air motor would need some kind of clutch to engage/disengage with the engine.
During accel the air motor is run in reverse to add torque to the engine.
No electricals involved accept for maybe the clutch.
whats wrong with that logic, besides crazy.
Old 08-22-2007, 07:25 PM   #8
punch
punch's Avatar
maybe could've saved a $1000 by not getting a/c in the first place...
out of respect for nutzoid, I changed my avatar.
punch is offline   Reply With Quote
Old 08-22-2007, 07:38 PM   #9
Astroman
Modded Moderator
Astroman's Avatar
In the US, air conditioning is standard. I don't think you can get a Yaris here that doesn't have it, unless you import it from Canada.
Old 08-25-2007, 03:26 AM   #10
flagmunkey
flagmunkey's Avatar
Drives: 2007 Yaris
Send a message via AIM to flagmunkey
so you're talkin about using the AC to compress air when braking then expelling it when accelerating?
sounds like a feat! id recommend trying it, but where woul dyou store the compressed air..
i remember reading that this type of "hybrid" was much more sustainable than a battery electric hybrid because it doesnt have as much embodied energy, and its more efficient.
flagmunkey is offline   Reply With Quote
Old 08-28-2007, 04:36 PM   #11
NimbleYarisOwner
Yaris my baby
The problem is i don't think the AC compressor can be run in reverse, but I might be wrong. Other problem is that i am not idpendently wealthy to by an extra ACcompressor from toyota to start messing with it/ figuring it out. Storring the compressed air is the easy part, I would just get 5 gallon tank, preferably aluminum to keep the weight down. There are allot of engineering variables to think about.
1) closed system, running Nitrogen? (removes water problem)
2) Cluching AC compressor in and out
3) compressing air is not the most effieicent process, from a Thermodynamic point of view but its probably the most reliable.
I cant understand why this type of idea hasn't gone any further at detroit or anywhere else? whats wrong with it?
Anyway the sloths in Detroit should be thinking about this, not me. I like air cause its clean and doesn't leave a mess.
I wonder how much an extra AC compressor costs anyway.
My other problem is I would need to get a decent CAD model of the underhood layout of the YARIS.
Old 08-28-2007, 07:09 PM   #12
BailOut
Steals terrorist's lunch
BailOut's Avatar
Storing air isn't linear. The more air you put into the tank the harder it is to get the air in the tank due to rising pressure. The more air you take out the harder it is to get out due to dropping pressure.
Storing electricity in batteries is much more linear.
- Brian
Share the Road
Old 08-28-2007, 09:28 PM   #13
swng
swng's Avatar
Drives: 06 3-dr auto RS
How about a flywheel instead of pressurized air? Please see Post #8 here:http://www.yarisworld.com/forums/sho...ybrid+flywheel
swng is offline   Reply With Quote
Old 08-28-2007, 09:48 PM   #14
CF-Shane
CF-Shane's Avatar
Drives: 1993 Toyota Terecel 2 door
Send a message via AIM to CF-Shane Send a message via Yahoo to CF-Shane
Coming from the minitruck world, there are a lot of off the shelf engine-driven-compressor solutions that could be valved to do the trick. However, I honestly don't know how much of a difference this will make (if any). I think the last couple of posts are a little bit more on the bead as to what's practical and not as lossy. Using a compressed air based solution, you will probably lose a lot of your energy to heat.
CF-Shane is offline   Reply With Quote
Old 08-29-2007, 12:18 PM   #15
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
An A/C system weighs far more than 15lbs. The compressor alone usually weighs 30-40lbs (on all the cars I've pulled them from - Nissans, Toyotas, and Mitsubishis). Theres alot more to the system than the compressor - dryer, lines, condenser, etc. All that together usually weighs close to 75lbs.
WRBlue is offline   Reply With Quote
Old 08-29-2007, 02:59 PM   #16
Thirty-Nine
Okay, so it weighs more. I'm still not sure I understand where we're going with this thread. Making the Yaris run on compressed air? I can tell you than an A/C compressor does not put out a lot of CFM compared to a stand-alone compressor -- in fact, not anywhere near the same volume.
Tata Motors from India has recently come up with a car powered by air. It requires a lot of pressure and needs the tanks filled after so many miles.
Old 08-29-2007, 03:35 PM   #17
NimbleYarisOwner
Yaris my baby
its not running all the time on compressed air, just helping to accelerate from standstill. The idea of a car running only compressed air does not make allot of sense.
I want something a home mechanic can do that will be fun to experiment with. Hey if i can get up to 40mpgavg instead of 35mpg avg then its worth it.
I like the idea of a hydraulic system, which would eliminate the inefficiencies of an air system. (hydraulic regerative braking systems are being worked on for trucks, i read in an article). The AC compressor would be perfect cause its right there already installed. If you could run it backwords it could work, but it probably can't be run in reverse.- so you would need to install a hydraulic motor. You would also need an bladder or spring accumulator to store the high pressure fluid and some valving.
I gota get out my refrigeration manual to see what psis refrigerent
compressors run at. and the horse power ratings.
Old 08-29-2007, 05:10 PM   #18
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
FUNNY that i saw this cause i just came back from my highlander hybrid class and i learned about regenerative braking.....
Brakes Geelmeel General Yaris / Vitz Discussion 16 06-29-2007 07:58 PM
Noise when braking hystria DIY / Maintenance / Service 9 05-02-2007 09:28 AM
