Old 09-19-2007, 05:52 PM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
don't forget the work on the transmission.
My kit comes next week, and I'm going to start with stock internals -- we'll see what she makes. It's all on paper until someone commits and completes.
what kit are you getting?
Old 09-19-2007, 04:40 PM   #2
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
http://myspecv.com/f/t1255-4-wheelhop-aid.html
Old 09-19-2007, 06:08 PM   #3
Black Yaris
der Zeck
so they are running 7-8 psi safely on the 1nz in the scion's with stock internals
http://www.turbo-kits.com/xA_xB_turbo_kits.html
http://www.365motorwerks.com/index.a...ROD&ProdID=254
so why couldn't we?
Old 09-20-2007, 06:09 PM   #4
joey1320
joey1320's Avatar
Drives: Yaris LB
so why couldn't we?
WE WILL my friend, WE WILL...
joey1320 is offline   Reply With Quote
Old 09-27-2007, 08:18 PM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Question? Why did you end up choosing the AEM FIC instead of the more common/affordable e-manage? Any particular reason??
Old 09-27-2007, 09:34 PM   #6
Because the eManage doesn't work. The stock ECU "learns" and compensates for any changes made by the eManage, at least from those who report actually trying it.
Old 09-28-2007, 04:15 AM   #7
CASTREX
CASTREX's Avatar
I thought that the learning issue would happen with any piggyback systems. Is confirmed that the AEM FIC will fool the learning feature of the ECU?
Old 09-28-2007, 09:34 AM   #8
nope, not that I know of!
Old 09-28-2007, 11:17 AM   #9
Black Yaris
der Zeck
Well I am going to buy a new clutch and lightened flywheel while I am at it, b4 I do the turbo
Old 09-28-2007, 11:26 AM   #10
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
New clutch, definitely. I was talking to this mechanic at a speed shop about boosting the car, and he recommended *not* getting a lightened flywheel... said it would make it "not fun" to drive..? Perhaps with the spooling of the turbo, the engine would be smoother with the stock flywheel?
2006 Red Blitzed RS 5-door
Old 09-28-2007, 03:53 PM   #11
Black Yaris
der Zeck
I do not see why it would make it not fun to drive
Old 10-20-2008, 08:06 PM   #12
Duskin_Carpentier
Drives: 08' Liftback,95' ///M3SC61
its not that it wouldn't make it as fun to drive. It basically can slow down how fast your turbo spools thus leaving you less rpms that you are actually making positive pressure. The reason being is because the heavier flywheel puts more load on the engine. More load on the engine = faster spool. Another example is the higher the gear the faster the spool. So if you are in 2nd and starts making boost at 3k rpm it will start even sooner in third because of more load on the engine. Lightened flywheels usually cater more to the n/a crowd.
Duskin_Carpentier is offline   Reply With Quote
Old 10-21-2008, 06:01 PM   #13
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
This is why you don't want to get a lightened flywheel especially on a boosted car.
Old 09-28-2007, 01:20 PM   #14
smokinyaris
smokinyaris's Avatar
Drives: bad boy
yo cali keep me posted on your kit...................since ur in socal
smokinyaris is offline   Reply With Quote
Old 09-28-2007, 01:43 PM   #15
will do -- suppose to be going in for coating next week, then shipped. I'll be doing a clutch also and probably the Kaaz LSD.
Old 09-28-2007, 07:02 PM   #16
Tapper
Tapper's Avatar
Drives: 2008 Black RS 2dr
I think the lightened flywheel would cause the clutch to engage different from stock. If you were to use an aftermarket clutch it would only affect it more. Also, the idle characteristics of the car can change.
Tapper is offline   Reply With Quote
Old 09-28-2007, 07:28 PM   #17
ddongbap
A lighter flywheel would cause your revs to die down a bit quicker.
Old 09-28-2007, 08:05 PM   #18
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Throttle response would be very twitchy depending on how light the flywheel is made. However, shaving a little weight off the stock flywheel will make a noticeable difference in engine braking as well as accelleration. As long as you don't lighten it up too much, throttle response should remain manageable. Talk to your machine shop and give them your projected crank HP numbers. After weighing the flywheel, they should have a suggestion for how much weight to take off depending on your application.
Galavoxx is offline   Reply With Quote
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
Under $2500 Tubo Kit Update cdydjded Forced Induction Forum 16 08-26-2007 11:05 PM
another small update on turbo kit. joey1320 Forced Induction Forum 6 08-23-2007 04:51 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
