Old 10-20-2008, 11:58 PM   #1
saplaymate
saplaymate's Avatar
Drives: 08' HB
[QUOTE=cdydjded;133318]Well I spent all weekend figuring out the wiring for the AEM FIC. Not that it takes that long to install but I was trying to find the easiest way to install it. I found the injector, cam sensor, crank sensor, switch power & ground. I still need the TPS signal & O2 signal. If anyone can help I would apriciate it. The manifold is done, turbo & I/C is on the way & the oil pan is getting modified for the oil return. Any questions please ask.
I'm a little confused on the wiring set up for the FIC, but I've never seen one or read it's instructions. The wiring may explain why others have had problems
First by O2 you mean A/F sensor, correct.
But I don't understand tapping into the injector or TPS signals?
On our cars fuel injection duration is controlled by the MAF input signal, so all that needs to be done is manipulate it and you can directly control injector pulse width. (I don't see why you couldn't do the same to the injectors signals)
Tuning injector pulse width in closed loop trims and open loop is simply modifying the MAF signal for the corresponding pressure & RPM. I know I've done it and researched Toyota's training junk.
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 10-21-2008, 01:42 AM   #2
maybe, but you should drive my car. The T25 turbo spools so fast and early it's amazing to drive -- I don't regret putting in the lightweight flywheel at all.
its not that it wouldn't make it as fun to drive. It basically can slow down how fast your turbo spools thus leaving you less rpms that you are actually making positive pressure. The reason being is because the heavier flywheel puts more load on the engine. More load on the engine = faster spool. Another example is the higher the gear the faster the spool. So if you are in 2nd and starts making boost at 3k rpm it will start even sooner in third because of more load on the engine. Lightened flywheels usually cater more to the n/a crowd.
Old 10-21-2008, 03:18 PM   #3
Duskin_Carpentier
Drives: 08' Liftback,95' ///M3SC61
ya i'm not saying it wouldn't be fun and im sure spool isn't a problem with that little guy. I even have a lightweight flywheel in my turbo M3, but i bought that when i was n/a and sold my stock. All i'm saying is if i were going to turbo this car i don't necessarily see the reason in spending money on a lightened flywheel.. thats all.
and in regards to whoguy i'm not sure if thats the mods i would choose if i was going for to imporve overall acceleration, assuming thats what his intentions were, but maybe im crazy? haha It may not seem that insignificant, but other turbo bmw guys have changed back from lightweight flywheel to stock and have seen actual imporvment in getting in boost sooner. The sooner you are in boost the better, but thats just my opinion.
Duskin_Carpentier is offline   Reply With Quote
Old 10-21-2008, 01:59 AM   #4
whoguy
Drives: Yaris YRS Sedan
cali..... I have to agree with you.
My cuz put a Light weight flywheel in his WRX and he said it was the best mod he'd done as in bang for buck.
Whether the rotational inertia puts more load on an engine.... I think the load from accelerating the vehicle would make the load from the flywheel insignificant.
whoguy is offline   Reply With Quote
Old 10-21-2008, 06:40 PM   #5
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
More likley the drivers fault,mechanics and or manufacturer but I agree to an extent.
bdc87 is offline   Reply With Quote
Old 10-21-2008, 06:46 PM   #6
true, not just for that, but if you have it all apart for a clutch upgrade, it's no more trouble. Throw the LSD in there too...
phxdemon, I'll show you my THREE cars that have lightened flywheels with boost that have never had a problem. I'm not sure what your point is -- is that your car in the pictures? Tell us more about it.
Old 10-21-2008, 07:03 PM   #7
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
No It just scares me because many time lightened means machined thinner than OEM. More than likely the driver revved his motor to 8k and dumped the clutch which caused that. What manufacturers make lightened flywheels for our car anyway?
Old 10-21-2008, 07:16 PM   #8
PHXDEMON
PHXDEMON's Avatar
That flywheel also looks like it was made with the same crappy metal they make most chrome rims with
Old 10-21-2008, 08:32 PM   #9
^ true!
Fidanza makes a flywheel for us, that's what I have -- and I think Clutchmasters as well.
Old 10-21-2008, 10:55 PM   #10
saplaymate
saplaymate's Avatar
Drives: 08' HB
Clutch masters does not, I called them back when I was in the market and they said, "we do not make a flywheel for Xb's, That they where frauds". (IDK?????)
0 - 60 in 3 shifts
Old 10-22-2008, 12:49 AM   #11
what about frauds? chill dude, I said "I THINK" they did.
I know one other company makes a flywheel for us.
Old 10-22-2008, 05:23 AM   #12
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
Fidanza is the shit had one on my blown 383 Stroker 280z. I loved that car but love the fiancee more damn.
ztrack157 is offline   Reply With Quote
Old 10-30-2008, 09:40 PM   #13
dallas
Drives: Yaris Hatch /Landrover D2
I had a lightened flywheel in my 3.5 altima While it felt amazing when accelerating in gear, felt better than the cai and headers together, when I went to the drag strip I was consistantly 1 tenth slower, even though the car felt much faster. I think while power shifting the mass of the lighter flywheel would not propel the car forward. The same way a lighter crank pulley makes the car feel much faster if you run at the track or have a G-tech you may be suprized with the results.
dallas is offline   Reply With Quote
Old 10-31-2008, 11:47 AM   #14
at3GG
at3GG's Avatar
Drives: 07 metmet LB
what is this 0-60 in 3 shifts all about? The top of 2nd is 60 if not 61, as I know Loren...? stated. Even if it wasn't...start in 1st...shift to second....shift to third=2 shifts.
Anyways....dallas, that doesnt really make any sense to me, hopefully someone can elighten us.
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 10-31-2008, 12:22 PM   #15
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Top of 2nd gear is 60mph on a standard US spec Yaris Tranny...
If you have a shorter Final Drive or a different tranny then you need to shift to 3rd to reach the 60mph.
That's what the signature is about....
Old 11-01-2008, 05:56 PM   #16
at3GG
at3GG's Avatar
yeah but 1st to second=1 shift second to third=2nd shift =TWO shifts lol
i guess they're considering putting it in gear before starting off a shift?? if its considered a shift then I concede.
Tanabe Df210's
Old 11-01-2008, 10:59 PM   #17
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
US Transmission shifts to 60 in second gear. I have a coupple vids that I am gonna post up soon of a 0-60 time you can note only 2 shifts.
Old 11-02-2008, 07:14 PM   #18
hitting 60 in 2nd:
http://www.youtube.com/watch?v=bk1YYkwOGtI
SOooooo... back to the topic, where the hell is this kit that was going to be ready in a week or two???
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
Under $2500 Tubo Kit Update cdydjded Forced Induction Forum 16 08-26-2007 11:05 PM
another small update on turbo kit. joey1320 Forced Induction Forum 6 08-23-2007 04:51 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
