![]() ![]() ![]() Drives: 07 Toyota Yaris Join Date: Feb 2012
hey i did my gear oil change i added 2 quarts and nothing leaked out? im guessing it didnt it didnt need to level itself out? should i add more? or just leave it the way it is
Angry Bird Crew #1 ![]() ![]() |
The 2 qts. will be fine .
![]() Drives: 2009 yaris Join Date: Jul 2012
Thanks, ttufrosty...This is how I will be spending my Saturday morn. Great DIY post...
Great DIY and I just want to give a few notes for anyone tackling this in the future.
- I didn't do this on my car until 75k. The fluid came looking brand new with no metal shavings. However, I was having some issues with the shifter being stubborn in cold weather, especially reverse. After the fluid change, the tranny shifts better than it did stock (as far as I remember) - A lot of people are recommending Redline, Royal Purple and other exotic oils...you don't really need that stuff. I used Pennzoil Syncromesh out of Autozone for like $8 a quart and it like I said, it shifts better than it did brand new. For reference, here's what it looks like: http://pennzoil.com/other-car-produc...mission-fluid/ - The 24mm socket size for the fill plug was impossible to find in 1/4 inch. I ended up buying a 1/2 to 1/4 adapter to do the job. - Buy whatever you need so you can do the fill from the top. I used a hand-actuated vacuum pump that I used to bleed brakes and it was a major PITA to do under the car. I did my best to put all 2qts in, but really as long as you can stick your finger in the fill hole (lol) and feel fluid, you've got enough in there.
To add^ its alot easier to fill the fluid from the reverse sensor port
![]() Drives: 2007 Toyota Yaris Join Date: Dec 2012
Just want to give a thank-you for the DIY. Made the job simple for me, faster than changing the oil.
I'm also interested curious about the reverse sensor fill method if anyone has a reference image? |
Drives: 2008 Yaris Sedan Join Date: Jan 2013
Hi guys! First post here but been lurking for a while. Just wanna say thanks to the one who made this DIY guide! I used 2 quarts of Redline MT-90 on our 2008 Vios (Yaris sedan's name here in the Phils.). Car has 42K ++ kilometers on the ODO. Will observe the gear changes later on, as I've read a lot of good feedbacks on this oil. Many thanks again Yarisworld. :)
![]() Drives: Yaris 2007 Join Date: Aug 2009
Can someone post a link to Amazon with Red Line that's MT-90 GL4 75w90 that has been recommended.
I can only seem to find MT90 that is 90w. Or if I do find the 75w90 MT-90 it's in 5 qt. I don’t know the difference from 75w90 and 90w but it seems most of you are recommending the 75w90. If possible would like it sold or shipped by Amazon to take advantage of prime shipping. |
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
did you try:
http://www.amazon.com/s/ref=nb_sb_no...T-90+GL4+75w90 Be careful with amazon prime.......it's kind of addictive ;) |
Thanks for the quick reply. Do you know if the oil link below is a 75w90, I know Amazon doesn't always do a good job with product descriptions and it say's 90w but am not sure if there is a difference.
http://www.amazon.com/Red-Line-50304...=cm_cr_pr_pb_t |
#12 | |
Which is an 07 manual hatchback that lives in the south Texas heat. |
Go here to possibly find a local dealer , http://www.redlineoil.com/dealers.aspx and here for details http://www.redlineoil.com/product.aspx?pid=46&pcid=7 . Let us know of your purchase and if any improvemnets in performance .
#14 | |
No local dealers within 50 miles. :( |
elo179 , you could ask a local private owned auto parts to possibly order it for you . That's what I did . AMSOIL has MTG ( 75w-90 , GL-4 ) synthetic and is usually easier to purchase . MTG , http://www.amsoil.com/shop/by-produc...r-lube-75w-90/ . Good Luck .
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
Anyone have a part number for the drain plug washer?
![]() Drives: 2007 Yaris Hatchback Join Date: Sep 2011
Drain/Filler Plug P/N: 90341-18033
Drain/Filler Plug Gasket P/N: 90430-18008 |
![]() Drives: Yaris 2008 Hatchback Join Date: Jun 2013
Thanks for the tutorial. As mentioned by others, the oil did gush out. All the oil must have come out in less than 5 seconds. I was thinking of letting it slowly drip out when it started coming out just before the bolt comes completely out and I should have :)
Somehow I had never changed the oil for the manual transmission and it was probably [over]due, currently sitting at 147 000 km... lots of highway kms but should have done it before. I used the marker trick and it worked really well for the top bolt. Bottom one fell in the oil pan and the mark came off. Filling it up with a funnel from Canadian Tire with a hose attachment worked like a charm. Looking up from underneath: photo 3.JPG Where I put the funnel. I moved the air filter cover sideways a bit to make the funnel go in a little more photo 4.JPG Funnel used: photo 5.JPG Cheers! |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Yaris Auto need help with tranny oil change | chrisada_to2a | General Yaris / Vitz Discussion | 2 | 05-17-2007 01:51 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 08:37 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
