Old 10-21-2008, 06:10 PM   #8
Smokey159
Drives: Yaris Liftback
So my yaris sedan auto was geting about 36mpg adverage. Thats with no special driving techniques just driving normally. After installation of my weapon r intake. My mpg dropped to 29-30. I attribute this to the relocation of the maf sensor. Since how much the injectors spray is directly tied to maf readings.
The MAF sensor is relocated just a few inches away from the throttle plate and i think that even though the same amount of air may be going into the intake at the same throttle position witht he stock intake the location of the sensitive sensor may get a false reading of air when accelerating. Maybe even at a constant throttle position.
I checked this by hooking up my scanner to the computer and watching live data readings of the fuel trim. If you know a bit about cars fuel trim should always be close to zero with a little switching picked up by the oxygen sensors. My fuel trim is at about 20 percent for long term.
Which means the car is constantly dumping additional fuel leading to my reduction of fuel economy.
I am curiouse to see what happens to my fuel trim if i put my factory air box back but install a simply drop in K&N filter.
reset the ecu. Unplug the battery for a few minutes, hook it back up and let the car IDLE for about 5 minutes, then shut it off.
you should be good to go again.
Smokey159 is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
How to Increase Gas Milage Pavel Olavich Performance Modifications 9 03-20-2007 07:58 AM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
