#1 | |
![]() ![]() Drives: 2010 5-door hatchback Join Date: Mar 2014
![]() ![]() Drives: 2013 3Dr Super white Join Date: Apr 2012
Fugitive
Drives: 2007 Yaris 4 Door Hatch Join Date: Jul 2014
what is the basic function of these cats ?
please suggest what option from below should i go, for the maximum HP gains .. regardless of fuel economy .. 1: remove both cats and resonator and put a straight down pipe of 2" or 2.25" ( please suggest which is better 2" or 2.25" ) till the end ... 2: keep the 1st cat and remove the second cat and the resonator and put a straight down pipe till the end ... 3: keep both cats and just remove the resonator and put a straight down pipe till the end ... 4: keep both cats and resonator just put a straight down pipe after the resonator till the end ... 5: remove both cats just keep the resonator and put a straight down pipe till the end ... |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
Remove both cats with 2" exhaust and magnaflow freeflow muffler
Fugitive
That's correct.
Fugitive
I can't tell you exact dyno numbers because I never visited a dyno after installing the exhaust but you will definitely feel the difference in acceleration. You will not regret doing it.
#9 | |
Fugitive
if i use 2 resonators in the middle .. just for lowering exhaust sound .. would it effect the performance ? |
I don't think so but with one resonator the car is quiet enough that it won't bother you cruising at normal speed.
Here is a video of my car with 2" exhaust, magnaflow imitation muffler(the original magnaflow should sound better) and a magnaflow 2" glasspack as a resonator. With the OEM Toyota resonator I think the car should sound better.
https://www.youtube.com/watch?v=d_tajogfKAk
#12 | |
Fugitive
#13 | |
Fugitive
the original OEM resonator in the catback which basically is the third one in line ... has 2" in and 2" out pipe width ? |
#14 |
Fugitive
Yellowww ...
#15 |
Fugitive
im getting too confused now .. :S
some say go with max 2" pipes some say nah its ok even if u take 2.5" pipes .. some say keep the 1st cat .. same say remove both cats and have only one resonator in between ... :S im surfing over the forums and internet from the last few days now ... but honestly speaking the more and more im reading stuff the more im getting confused ... :S i did experimented one thing ... i put a 1.7" pipe ( 1.7" measurement from inside ) from the neck of the headers, removed both cats and resonator till the rear bumper and installed a topspeed muffler at the end ... the inlet of the muffler was 2.5" |
#16 |
![]() ![]() ![]() Drives: 09 Blizzard Pearl RS LB Join Date: Sep 2009
^ It depends what your long term hp goals are to determine which pipe diameter to go with. Here is a good read:
http://www.magnaflow.com/07techtips/faq/question10.asp
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna |
#17 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
finally got around to getting mine back on the dyno with the current exhaust...no real difference over the old set up peak vs. peak...but after peak power was up like 7whp...
http://www.youtube.com/watch?v=yRBfjMLSNDU
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#18 |
![]() Drives: 2012 toyota yaris le Join Date: Sep 2014
Removed stock muffler and replaced with shown baffle and tip. I think it sounds pretty good!!
| DIY: Installing Greddy TI-C Exhaust System | redyaris | DIY / Maintenance / Service | 13 | 08-01-2009 04:05 AM |
| Why is DTM exhaust thread closed? | gr8yaris | Performance Modifications | 4 | 01-13-2007 11:01 AM |
| Fujitsubo Exhaust!! | MC-BPT | Sponsors Classifieds Area | 17 | 11-16-2006 10:36 AM |
