Old 01-09-2009, 06:01 PM   #1
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Originally Posted by coheed View Post
Thats hot man. Is that the stock but with a custom pipe on it? Its nice either way.
Yes it is , stock with custom pipe work , no need for axle or cat backs here
as we have a 90 decibal limit on Exchaust noise .
Old 01-23-2009, 08:34 AM   #2
06silveryaris
Drives: 2006 yaris
Originally Posted by 2DtheDon View Post
Hiii...am loooking to add an exhaust system for my yaris hatchback the problem is i couldnt get any here in Bahrain,and i checked online but the shipping price is too much,some friends told me to do custom one do u recommend that?and like just adding a Hks or greddy muffler?
Go custom, this way you can go cat back rather then just axle back(rear section) and get it done localy without crazy shipping charges. As far as the muffler those will work and you can also try a dynomax turbo muffler or similar, which will keep the sound deep and very pleasant.
06silveryaris is offline   Reply With Quote
Old 01-24-2009, 10:13 AM   #3
mrbond
mrbond's Avatar
Sorry for this noob quesiton but whats the difference between the catback and the axle back?and is it true that the axle back has no increase on the HP?
It's not necessarily true that an axle-back won't increase horsepower. It depends on how restrictive it is and/or the baffling design. It is mainly for sound, however, due to the design of the Yaris exhaust system, that's the only thing you can change other than getting a whole midpipe. A catback system goes from the catalytic converter all the way to the tip, and will result in a higher hp gain.
Hope that helps.
Old 01-24-2009, 11:11 AM   #4
Hope that helps.
you can always cut your midpipe after the resonator (which is 2" thru) and replace the res-back piece which is 1.75" with a bigger pipe. just weld it on....i had to do that w/ my XRS and my magnaflow catback i bought for it....either clamp or weld...
from what i read, you gain tq across the powerband (thus increasing hp past 5800 or so fairly significantly) with just an axleback due to the stock mufflers extremely restrictive design...
Old 03-21-2009, 01:27 PM   #5
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Hey thanks! It IS loud. haahha. I'm working on getting a longer resonator and maybe throwing a hi flo cat on there.
Hawaii does NOT recquire smog inspections! we are allowed to not have any cats. whoohooo!
Well I was getting around 38-40 mpg before the S/C, but now I am getting around 29-31 mpg. It IS a sacrafice, but I believe the trade off is worth it.
Removal of all of your cats is definitely not legal in hawaii. Yes, we have no smog inspect., but they can check to see if you are running catless.
anonymous user is offline   Reply With Quote
Old 04-07-2009, 06:59 PM   #6
revoturbo
revoturbo's Avatar
Drives: yaris
NIce works..
multimakmurperformance.com
revoturbo is offline   Reply With Quote
Old 05-18-2009, 11:22 AM   #7
nisyota
Are you not listening to me. You will lose torque going with 2.25". You don't need it that big. But whatever you want.
i have to agree with peterpoop... im running 2.25" pipes on my Nissan Titan (5.6L 321hp with 353 ft lbs/tq running 13.88 in 1/4 mile)... Originally the pipes are only 1.98". If i go up to 2.5" than ill be losing enough low end torque that i cannot get a good 60' time. BUt, the high end will be better since the flow will be faster... But for low to mid range, i think 2.25" is a little high...
test them at a Drag Race Track. Doesn't matter the driver, well kinda does. But take 2 yaris'. Same Mods, except the only difference is that one is 2" piping and the other is 2.25" pipes. You will see that the 2" will have a better 60' and all the way up to the 1/8 mile... BUt after that the 2.25" will take over because there is more air flow...
But, this isn't really the thread to discuss this. I just had to put this out there since there is also confusion with my truck with other people thinking bigger is better, which is not... :D
Oh, how come i see more pics than videos of the exhausts? I want more videos and more burnouts. LOL
nisyota is offline   Reply With Quote
Old 04-25-2009, 03:13 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
Anyways, the power from a NA yaris will lose torque with 2.25" piping. I'm leaving it at that.
please prove this blanket statement with dyno graphs of a stock exhaust yaris vs a 2.25" exhaust, done on the same day, same air temperature, same humidity, same yaris.
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
Why is DTM exhaust thread closed? gr8yaris Performance Modifications 4 01-13-2007 11:01 AM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
