Old 11-03-2008, 12:27 PM   #1
b_hickman11
Drives: 08 Sedan
When was the last time you checked and replace your cabin air filter? Sometimes these can become so clogged up that it will cause the AC to overheat. Depending on what kind of trash is stuck to the filter, it could ignite from the over heating of the AC....Just a thought.
Old 11-03-2008, 12:49 PM   #2
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
It looks like the fire started here, so i will ask this again to the OP: is this a flashlight?? if so this could have caused the fire, the batteries where exposed to extreme heat. It looks like the fire traveled up form this point destroying your dash and gauge cluster.
Old 11-03-2008, 02:01 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Attachment 10933
I think you are right. I think there is a warning on most batterys do no leave in sun or prolong heat.
Atleast you were not inside the car driving while it caught on fire and no one was hurt.
Dealership is probally not going to try to accept blame on it so either way if you have full coverage insurance you are covered. Now you can get a 09 yaris =)
Old 11-03-2008, 03:34 PM   #4
stran
Drives: '07 Yaris 3D HB Auto
Holy Smokes! (no pun intended ;))
If someone has time, they can look through the service manual and figure out what's actually behind the dash. If the ignition is off, most of the wires will not be live, so that would narrow down what could cause the fire.
I don't think the flashlight is a cause. Only lithium batteries will vent flames, and I really doubt that flashlight used lithiums. Alkaline batteries might explode and release hydrogen gas but won't start a fire.
Best of luck getting Toyota to cover the damage. Let us know what happens.
stran is offline   Reply With Quote
Old 11-03-2008, 03:44 PM   #5
stran
Hmmm, thinking about this some more, there are two variables to measure flames: heat and temperature.
A large wood fire would have a lot of heat but low temperature. An acetylene torch would have very high temperatures but low heat. In order for a fire to start, the temperature of the flame must be above the ignition point of the fuel and there must be enough heat to raise the fuel to that temperature.
A cigarette butt would have temps up to 1300F. An electric spark, judging by its blue color, could have temperature well over 3000F. http://en.wikipedia.org/wiki/Fire
Here is a good link to fire forensics. http://www.tcforensic.com.au/docs/article10.html Though the cigarette butt has the sufficient temperature to ignite plastic, I doubt it has enough heat. Electric sparks on the other hand, is powered by the battery, which as +100 watt*hr of power.
Old 11-03-2008, 04:17 PM   #6
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
Maybe a Spontaneous Combustion..
http://science.howstuffworks.com/shc.htm/printable
Old 11-03-2008, 04:36 PM   #7
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Okay...... here is an experiment that people will try but I will warn you in advance ...... this is usually accompanied with KIDS DO NOT TRY THIS AT HOME!!!
Batteries are dangerous regardless of size.
Get a 9 volt battery and some fine steel wool....... grab a chunk of steel wool and fluff it up to about the size of a golfball. Now touch the steel wool with the 9 volt battery (you might want to wear gloves) and make contact with both + and - on the 9 volt. Near instant fire! Thin wires burn very easy and considering there is 12V in the dash and tin wires..... you get the picture. http://www.youtube.com/watch?v=KvDBtBUfk_I
Now go clean out the junk draw in the kitchen or workbench and make sure you do not have any old batteries stored near steel wool.
Old 11-03-2008, 07:13 PM   #8
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Actually this car looks like a repairable writeoff.
If Toyota won't cover this car, you might want to explore the possibility of locating a repairable writeoff donor in a wrecking yard yourself and grab as much of the interior as you can, because yours will be smoke damaged. With the exception of the top dash panel through which the passenger side airbag blows, the rest of the dash usually don't get damaged in an accident too badly. After removing the burnt stuff, it should be fairly easy to repair or replace what's you need.
And you definitely need a new window. By the way, what trim is your car, YR, YRS or YRX?
Good luck. I spent quite a bit of time crawling through wrecked cars looking for parts myself. If nothing else usually you can come away with a pocketful of automotive fuses.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 11-03-2008, 07:28 PM   #9
purpleminx
Drives: '08 5DR Silver Yaris HB
It's insured, so even if Toyota doesn't take the blame, my insurance company will replace it. They're the ones who told me to get Toyota to tow it over to their workshop, actually.
My car was a YR.
Originally Posted by Stargate YARlantIS View Post
Was there any aftermarket sound system?? maybe faulty wiring?
No, all Toyota. Like I said, I never installed anything, never changed anything, and all services were done by Toyota.
purpleminx is offline   Reply With Quote
Old 11-03-2008, 07:19 PM   #10
Stargate YARlantIS
Stargate YARlantIS's Avatar
Visualize whirled peas.
Peace, Love and Good Smoke!
--Tommy Chong
Stargate YARlantIS is offline   Reply With Quote
Old 11-04-2008, 12:23 PM   #11
b_hickman11
Drives: 08 Sedan
did you have a cabin air filter????
Old 11-04-2008, 02:18 PM   #12
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I have to seriously contest the flashlight battery theory. A couple of problems: there should be soot/melting directly above the flashlight, and the tray itself should have melted substantially; the flashlight should show significant damage, yet appears basically unscathed. Also, that flashlight appears to be one of the aluminum screw-together type, which would be at least semi-waterproof. It would need to burst somewhere at its seams or at the lens, which also doesn't appear to have happened. Finally, alkaline batteries are safe at temperatures of 180 degrees Farenheit plus, and it would be tough to produce that even here in Dallas in August.
Anecdotally, I have kept a mini maglight and a 6V lantern in my car/trunk for most of the past 20 years in Texas, including in a black CRV, and never had the slightest hint of heat damage/leakage/combustion. Also, my brother used a maglight in Afghanistan and Iraq, where temperatures routinely exceeded 120 degrees farenheit AIR temp. No idea what that translates to inside a dark-colored, armored and sealed HumVee sitting in the sun all day, but no flashlights exploded.
One other thing: I don;t know about Aussie Toyotas, but US Yarii have the 12V outlet wired to the ignition, so no power would flow to the GPS when the key was out.
Old 11-04-2008, 02:29 PM   #13
darthbauer
Not really here...
darthbauer's Avatar
Did you have a car charger for your mobile phone in there?
I remember one time with my old Accord that it got so hot it sparked. I unplugged it and never used it in the car again.
Liberate Tutemet Ex Infernis.
Old 11-04-2008, 03:09 PM   #14
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
That is the case in Australia as well.
rob323 is offline   Reply With Quote
Old 11-06-2008, 12:02 AM   #15
auxmike
auxmike's Avatar
Did the flashlight use Lithium batteries?
I have a small Streamlight Scorpion in my glovebox right now. I left it on while it was standing upright on it's lens on a table, the lens started to melt! Those lights run HOT. After seeing this, I'm removing my Scorp from the car in the morning.....
Old 11-06-2008, 04:25 AM   #16
purpleminx
No, and it was nothing to do with the flashlight.
Originally Posted by k r a y z e e . j o j o View Post
Did you leave your phone hooked up to it? Ask because the back of my phone gets kinda hot when it's been charging for an hour or so. Just a possibility...
No, and it didn't have power going through the cable anyway, considering I was not in the car, so the keys weren't either ;)
Very close right now to finding the cause. Will definitely post their answers.
Old 11-06-2008, 06:31 PM   #17
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Hmm, that's a stumper...
Old 11-09-2008, 11:39 AM   #18
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
I'd check to see that your Scorp is legit. IIRC, they have a glass lense.
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
Toyota Silver Dash Kit Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 72 04-13-2012 01:42 AM
Trade upgraded radio and dash for base radio and dash??? Yarisguy13 Items for Sale by private party 4 09-17-2007 06:32 PM
dash problems...help needed foggy08 DIY / Maintenance / Service 1 01-25-2007 08:04 PM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 11:51 AM
