#19 |
toyota
#20 |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
i guess with a manual you can pull to the end of 4th gear instead of 3rd gear. what does 4th gear top out at on the manual?
#21 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
ive gotten 118mph numerous times in my 08 yaris hb coming home from NC i hit the goven a few times all its does is cut ur fuel for a few seconds so u slow down... if u stay at redline long enough it does it then to... ive personally done both.... as soon as i get my 15" back on ill use my gps again... see with 17" my speedo said 118.. my gps said 109... so when i get the konigs that i want ill try again
just for the record... i hit 118 in 4th gear...
"It hurts more when its wet" |
#22 |
does not work... i tried that on the way home... lol
#23 |
I just hit about 117-118 mph (about 187km/h). Completely stock 2dr LB. Rolling on stock 15" steelies.
I didn't let off the gas, but at the limit, it felt like the gas pedal let off by itself, or something. I don't have a tach, so I'm not sure if it was fuel cut off, RPM limit, or speed governer??? |
#24 |
Touge Driver
i did 206Km/h, and it was still going.
#25 |
![]() ![]() Drives: Vios Join Date: Oct 2008
i was still using stock 15" but with 195/55/15 tyres when i ran the car to its limit so i dont think theres a speed governor on my car hehe thailand vios dun hve speed limiter?
#26 |
Touge Driver
if there was a limiter, then my Apexi RSM must have overided it..
#27 |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
i did 120mph uphill
#28 | |
1NZ-FE
#29 |
Parallel Parking Pro
This car's got a relatively "soft" rev limiter such that it doesn't bounce off the redline like most other cars do when you over-rev it.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#30 |
Vroom Vroom Beep Beep
Governor on us models clicks in at 118 the gearing on the car suggests 148 mph without it but that is not taking into account the drag on the car pushing 130 would be hard in this car.
#31 |
aka Jack Wolfskin
129 mp/h on GPS
#32 |
![]() Drives: 07 abosolute red Yaris Join Date: Mar 2007
i can only go 88 mph before the flux capacitor kicks in.
#33 | |
Beast
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#34 |
Just call me Ray, better?
#35 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
haha that was good
#36 |
with my new intake filter and mid-pipe i'm going to try this again. maybe i should wait until i have my lightweight summer wheels on though because right now i'm using winter tires... although, the cold air probably makes more power...
| Max Speed in Each Gear for 5 speed man. Yaris with no tach?? | 09TRD | General Yaris / Vitz Discussion | 53 | 09-24-2010 04:18 AM |
| Tire Pressure Max | deebrown | DIY / Maintenance / Service | 82 | 08-10-2007 09:44 AM |
| Finding a 5 speed LB to test drive | grampi | General Yaris / Vitz Discussion | 16 | 05-10-2007 07:58 AM |
