Old 11-26-2008, 05:27 PM   #1
gboezio
gboezio's Avatar
Drives: Yaris 4dr 2008
Originally Posted by jkuchta View Post
Gboezio and WolfWings....you're both about half right.
Stainless and Mild steel both have high melting points, but Stainless conducts heat far less than mild steel, making it much better for exhaust applications. Also, stainless is much less susptable to scaleing and errosion than mild steel, making it even more superior in this application.
As far as embrittlement...while it will happen, the reduced fatigue strength of 304 will still be higher than that of mild steel, making for a stronger header.
My bad, I did not specify coated mild steel. I would not run an uncoated steel header.
Maybe 304 would work fine on non turbo application, someone's got to try
gboezio is offline   Reply With Quote
Old 11-26-2008, 12:46 AM   #2
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
think it will sound like this?
tein yaris
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 11-26-2008, 02:29 AM   #3
jkuchta
Drives: 2007 Yaris hatch (red)
Thanks a lot for looking into the stainless option for us Richard.
Also, ...about that split header flange.....
How are you bolting this thing onto the cylinder head? Are you not using the center bolt (i.e. only using 4 header bolts)?
jkuchta is offline   Reply With Quote
Old 11-26-2008, 01:44 PM   #4
richardholdener
Drives: 2008 Yaris hatch
The prototype header employed a split flange to facilitate installation, but production pieces will have a single flange like the stock ex man. The header will be two piece, but the connection will come down on the primary tubing. The header has to be a 2-piece design to allow for installation. On the prototype, we did use the center bolt but with a washer to secure both halves-it worked great.
richardholdener is offline   Reply With Quote
Long Tube Header kou Performance Modifications 2 11-18-2008 01:15 AM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
Megan Header Dyno Results ChinoCharles Performance Modifications 83 02-21-2007 10:06 PM
