toyota
bump anyone here has shots of the yaris car pager stock..connections and wire harness..??
toyota
#4 | |
(b) Answer-back function: • The main body ECU receives the door unlock detection switch's ON / OFF signals and uses these signals to confirm if the door control operation has been completed. The main body ECU then outputs the hazard warning light control signals to flash the hazard warning lights as an answer-back indication. It is considered to be a "customizable parameter", which can be changed by the dealer: 5. WIRELESS DOOR LOCK CONTROL SYSTEM Main Body (Main Body ECU) Display (Item) Default Contents Setting Hazard Answer Back ON When wireless lock switch on transmitter pressed, illuminates all hazard warning lights once. When unlock switch pressed, all hazard warning lights illuminate twice ON / OFF Wireless Control ON ON /OFF of wireless door lock function ON / OFF Panic Function ON Operates security alarm when panic switch on transmitter continuously pressed for 1 second ON / OFF Unlock / 2 Operation ON Function that unlocks driver side door when unlock switch on transmitter is pressed once, and unlocks all doors when pressed twice. if setting is OFF, pressing unlock switch once makes all doors unlock. ON / OFF Auto Lock Time 30 seconds Time until relocking after unlocking with wireless door lock function 60 seconds / 30 secondss |
| FS: AFE drop-in filter and Stock Airbox with Cutouts | FunctionSpec | Items for Sale by private party | 16 | 06-02-2010 01:36 PM |
| STOCK SEATS OUT OF HB / stock tires/rims | mrrock | Items for Sale by private party | 19 | 08-19-2009 04:56 PM |
| Stock 6 disc MP3 deck + speakers for sale!!! | chino_potato | Items for Sale by private party | 16 | 02-05-2009 07:27 PM |
| noob question about stock tires | xCookiE | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 06-19-2007 08:40 AM |
| question about stock stereo wiring? | punch | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 07-19-2006 03:22 PM |
