df210
just finished installing the df210 spring.. maybe it because of the bad qualite of the road here.. but when i hit BIG hole.. not normal hole it rub .. but i give a very nice loook :p maybe because of the tire.. 205/40 17
Well you said you hit a BIG hole... and you are now that much lower... what did you expect??
damn that mean i have to drive with the eye on the road now lol
anyway very goood you how-to chris help me a lot! but took me 4 hours to change it hahah
#5 | |
Can't wait to see your new pics with lowered car...
Whats the offset of your wheels, and do they just rub on the inside of the fender well?
40 for the offset and they rub juste a little on the plastic on the inside maybe i can unclip it.. night was coming and couldnt work on that ;p
![]() ![]() ![]() Drives: 2k3 Cavalier & 2k2 Echo Join Date: Aug 2006
Do you guys think this drop will ever rub with the stock 185-60-15 on the car? Just wondering because it was very low!!
2003 Chevy Cavalier Ecotec - His car! 2002 Toyota Echo Sedan - Her car... FOR SALE! |
i dont think because first the stock wheel are a little smaller(diameter) than what ive put.. and mine are much larger..
#11 | |
![]() ![]() ![]() ![]() ![]() Drives: icebox Join Date: Apr 2006
becareful if you have rubbing issues... and make sure to get an alignment done... you don't want any premature or unusual wear on your tires...
doing the allingnement monday.. and anyway if anything happen with the tire
ill buy new one lol |
Here is the differences in the tires. You would be suprised at the small difference. I think its because the offset on the stock rims. Does anyone know what that offset is on the stocks?
185/60-15 4.4in sidewall 11.9in Radius 23.7in Diameter 205/40-17 3.2in sidewall 11.7in Radius 23.5in Diameter 185/61-15 74.6in Circumference 850 Revs/Mile 205/40-17 73.7in Circumference 860 Revs/Mile |
i had 14 inch rim stock with 175/65 tire on
Here is the tire calculator I use. Just put both the old tire size and the new tire size and they compare them.
http://www.eunos.com/tirecalc/ |
Hey Chris do you have any idea what the offset is with the stock wheels on the 185/60/15's. We were worried that +40mm wouldnt be enough and now it seems to be too much. I have 215/40's on with a +40mm offset and I took it to a friend of mine that does suspension work and he said I should be ok from rubbing.
im gonna have to put the NF ... i took the worst street of my city and i almost cut the tire ;p so im gonna keep it 1-2 week and order the nf
| TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 10:26 PM |
| TANABE DF210 SPRINGS AVAILABLE!!! | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 08-05-2006 01:28 AM |
| Any photo with DF210 sedan 4 doors | mariosuper | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 07-26-2006 03:04 AM |
| IS DF210 is lower than Nf210 ?? | mariosuper | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 07-08-2006 11:36 PM |
