Old 11-25-2008, 02:14 PM   #1
ah cool so where they enter the ENGINE ecu they're pulse signals, then they go out to the cluster as pulses (correct me if i'm wrong, i recollect setting up a Defi VSD heads up display, and grabbed pulse signals for tach/speed) and the ECU also sends analog outputs to the TPMS?
do you have a wiring diagram of the ECU?
The ECU sends the same pulsed signal to the cluster and the TPWS. The Combo Meter has a microcontroller, which reads the tach and VSS inputs directly, as well as a CAN bus interface to get the odo data and MIL input from the ECU. All of the "data" signals are 12 V, so the microcontrollers have to level shift them to use them (via optoisolator, A-D, etc.).
The Defi's micro would have to do the same thing. By the way, was the Defi VSD worth the money?
For the wiring diagrams, I just have the 09 service manual.
Old 11-25-2008, 02:20 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i've installed 3 sets.. one on my xA the base VSD.. it was essential to life for me until it was vandalized :( it would record max speed/RPM which worked well for primitive datalogging at autocross..
the second one was the VSD that would hook up to the LINK system.. this one went in the yaris. speed/tach on the windshield is awesome..
i now have a VSD-X for my xA.. it has its own screen. i had it installed for a bit then removed it. it's a nice piece but a little OTT for this build. i believe DEFI has discontinued all their HUD's..
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 06:53 PM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
