Old 11-26-2008, 01:27 AM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Originally Posted by mikenacarato View Post
:( sorry to hear about it. why didnt the rail sit tight?
I don't know much about fuel injectors but ours are plastic things that just push into the fuel rail and are held in place by the o-ring. As Doc has said, you need to lube these with WD-40 before seating them into the fuel rail. I did not do this and I thought that the injectors went in fine. Apparently not.
Old 11-26-2008, 02:02 PM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Don't use WD40, use vaseline. Also inspect the o rings very carefully. If you cut one you will need a new one, and the car will never run right. The o rings are made of a different material so they arent broken down by contact with gasoline.
Blitz s/c info cont'd cali yaris Forced Induction Forum 36 03-10-2009 12:33 AM
Blitz S/C on 08 Yaris whooppee777 Forced Induction Forum 12 11-26-2008 01:45 PM
Which options are dealer installed? grampi New YARIS Purchase Forum 4 07-30-2007 01:23 AM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
