MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Under Car Turbulence
Way back 40 years ago several road racer types cut their times a lot by smoothing under car air flow. Its such a good trick that NASCAR requires you to use stock floor pans when you build a car. Some racers modified floor pans to create large down forces at speed. Great in the turns......unless you suddenly loose that suction for some reason.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
