oh yeah, OBX. also cheap. ha!
i think the manifold design is due to the placement of the catalyst as near to the engine as possible to aid in warm-up. i have a weapon R. i have never used a DC. ha! |
I have the TRD. My car enjoys it alot, lol.
#4 | |
you aren't going to find one new for less than nearly 700...before shipping. When they first came out it was 1000 bucks. There's currently a used one up for sale in japan for ~500. |
![]() Drives: Yaris YR 2013 Join Date: Feb 2017
the headers I have are a OBX or a copy or something made by GODSNOW?? fit perfect expect for the fact they are a tad (10mm) longer and are causing the cat converter to bump on the x-member, stil lto fix it properly butfor now I'm using the natural elasticity of the exhaust and hangers :) made a nice difference to note and revs also throttle off is not as drastic.
Most of my Yaris stuff including my DC header was purchased off ebay. It's negative connotation is due to the early years of ebay, many top brands use ebay to get their parts out there, just be smart about the brands you are buying.
Typically a 4-2-1 gives more low end torque and a 4-1 gives more upper. However, we are talking about true long tube headers such as the RPM header for the Tsport or XD which tends to give all that extra power above 3k rpm as it is a 4-1 header. With the Yaris headers, they are so short due to the rear exhaust exit that it doesn't seem to make a noticeable difference in which design you go with. I had the DC header and noticed a shift of the power band left by about 500 rpm and it seemed to perform better up top. That said, it wasn't until I got the MicroImage intake manifold that I noticed a big difference in the upper rpm's. ...still fell on its face about 5.5k rpm compared to the 2zr though... IMO if you don't plan on doing other flow mods ie: custom exhaust, air intake, intake manifold, 1zzTB, then I'd go with a 4-2-1 design. If you plan on improving the air flow of the 1nz with other mods then go with the DC header. Either way you'll be happy
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
So just for example, does this one look legit?
http://vi.raptor.ebaydesc.com/ws/eBa...=1492913724413 Or maybe this one? http://m.ebay.ca/itm/06-09-YARIS-1-5...ATCHING_ACTIVE Sent from my phone with Tapatalk. Please excuse any typpos. |
#8 | |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
sizing
I am trying to determine which header for me. I do highway, but also like my low end. I am steering to a 4-2-1, or like design, but think the tubes should be bigger/posters had some copied/pasted sizes below.
Tolmach ^ Mine measure 31 mm = 1.22 inches Golddeenoh Tolmach, your pipes look kind of small as well but then again my Megan Racing header is 3mm larger diameter but i wouldn't think that i could tell the size difference in a picture with out side by side comparison. Tooter The inside diameter of stock 2012 header runners is 28mm and the Weapon R's are 36mm... Xnamerxx I measured 35mm for the port and 40mm for the gasket. So, for the ceramic coating is nice, but T409 is not as super duty as T304, at least what someone typed online here: http://www.autoanything.com/exhausts...s/t304-vs-t409 I was leaning towards OBX as their claim is 1 3/4 primaries which is 44 mm. It looks like the stock, so it won't have the lower end lacking, as not as much high end as the DC. Looking at sellers sites, it is hard to see all the sizes, they don't have em, really. I think 1 3/4 is a big boast, hopefully Amazon is right. For now, I will await other replies, but based on research so far, am leaning to the OBX for the steel type too, the T304 besides the bigger tubes and similar construction to a 4-2-1 set up or stock set up.... Thoughts and sizes anyone ? ![]()
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
No idea about either of those brands. They are very cheap when compared to a dc header but cheap headers are also known to have cheap welds.
If you don't mind wrenching on the car a lot then you could try the cheap one, but if you want a reliable header that you install and forget then go with a known brand like dc
#11 | |
Sent from my phone. Please excuse any typpos. |
i'd say, "you get what you pay for" in most cases. cheap manifolds usually don't line up just perfect or have the best geometry or welds. i had an obx on my civic for over 200,000 miles without any issue. ($50) but, i'm also a cheap-ass and look for a better deal, and the complete exhaust was custom, so it did not matter if it lined up when purchased. i would not pay $500-$1000 for a TRD seeing how the gain is so minimal.
i do disagree with the 4-2-1 vs 4-1 for performance stated above. 4-1 manifold gives a better top end torque because of where the collector location is in reference to pressure point of cylinder pressure drop during high rpm. (high rpm=high pressure scavenging further in the tube) 4-2-1 allows high pressure scavenging to occur at lower rpm, between sister cylinders; wile high rpm scavenging still occurs, but at lower pressure, so it has a less dramatic effect on high end performance. since i do a lot of city driving, the most noticeable gains should live in the 500-3500 range. (4-2-1) i do not believe there is a "better" design, i think it all depends on where in the RPM range you want the gains to be most noticeable. in the civic, i was driving from denver to phoenix every weekend. (1500 miles r/t) the obx was a 4-1 because it was always on the highway running as fast as possible. it all depends on your utility. |
Ordered OBX header and TC TB spacer off Amazon. Buying two items off Amazon from OBX netted me 33 bucks off and was 12% their math. Was 199.99 and 74.99 before discount.
