#181 |
![]() ![]() ![]() Drives: 2010 5 Door Join Date: Feb 2011
I just installed mine yesterday and i LOVE it. it was a PITA to take out the stock header without a 12mm deep socket.. so if you are thinking of getting the dc header make sure to get one! I ended up going to the store to pick one up when i got to the last bolt.. lol. No CELs and no leaks! Definitely recommend it.
I have an afe short ram, trd axleback, MI pulley and I'm an AT. I definitely feel a difference and getting to 60-70mph is like butter.
lol okay |
#182 |
![]() Drives: Yaris RS2 2012 Join Date: Oct 2016
TRD made a 4-1 header (exhaust manifold) for the Vitz 1NZ-FE.
#183 |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
#184 |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
yeah. it's not even useful information...
#185 |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
OK, I would love to know if there are any other good headers out there which give similar low Rev improvements.
Sent from my phone with Tapatalk. Please excuse any typpos. |
#186 |
Weapon R is for low RPM gains
DC is for high RPM gains Megan is....idk cheap? |
#187 |
#188 | |
This is likely due to the fact that our headers are so short because of the rear exit design which doesn't make the headers act like tradditional long tube deigns That said I've never used the weapon r header
#189 |
oh yeah, OBX. also cheap. ha!
i think the manifold design is due to the placement of the catalyst as near to the engine as possible to aid in warm-up. i have a weapon R. i have never used a DC. ha! |
#190 |
I have the TRD. My car enjoys it alot, lol.
#191 |
#192 |
![]() Drives: Yaris YR 2013 Join Date: Feb 2017
the headers I have are a OBX or a copy or something made by GODSNOW?? fit perfect expect for the fact they are a tad (10mm) longer and are causing the cat converter to bump on the x-member, stil lto fix it properly butfor now I'm using the natural elasticity of the exhaust and hangers :) made a nice difference to note and revs also throttle off is not as drastic.
#193 |
#194 |
Most of my Yaris stuff including my DC header was purchased off ebay. It's negative connotation is due to the early years of ebay, many top brands use ebay to get their parts out there, just be smart about the brands you are buying.
Typically a 4-2-1 gives more low end torque and a 4-1 gives more upper. However, we are talking about true long tube headers such as the RPM header for the Tsport or XD which tends to give all that extra power above 3k rpm as it is a 4-1 header. With the Yaris headers, they are so short due to the rear exhaust exit that it doesn't seem to make a noticeable difference in which design you go with. I had the DC header and noticed a shift of the power band left by about 500 rpm and it seemed to perform better up top. That said, it wasn't until I got the MicroImage intake manifold that I noticed a big difference in the upper rpm's. ...still fell on its face about 5.5k rpm compared to the 2zr though... IMO if you don't plan on doing other flow mods ie: custom exhaust, air intake, intake manifold, 1zzTB, then I'd go with a 4-2-1 design. If you plan on improving the air flow of the 1nz with other mods then go with the DC header. Either way you'll be happy
#195 |
So just for example, does this one look legit?
http://vi.raptor.ebaydesc.com/ws/eBa...=1492913724413 Or maybe this one? http://m.ebay.ca/itm/06-09-YARIS-1-5...ATCHING_ACTIVE Sent from my phone with Tapatalk. Please excuse any typpos. |
#196 |
No idea about either of those brands. They are very cheap when compared to a dc header but cheap headers are also known to have cheap welds.
If you don't mind wrenching on the car a lot then you could try the cheap one, but if you want a reliable header that you install and forget then go with a known brand like dc
#197 | |
you aren't going to find one new for less than nearly 700...before shipping. When they first came out it was 1000 bucks. There's currently a used one up for sale in japan for ~500. |
#198 | |
Sent from my phone. Please excuse any typpos. |
