Old 08-16-2006, 06:00 PM   #1
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
TRD lowering springs' and/or shocks' Ride Quality??
greetings everyone. my wife and i have decided to purchase a liftback, but are undecided on whether to lower the car or not. the biggest concern is that she will use the car mainly for everyday commuting. although lowering the car makes it look sweet, does the ride quality suffer that much, or will the lowered yaris still be good for everyday commuting on a good combination of city and highway?? any input would be greatly appreciated from those who have the TRD lowering springs and/or shocks. THANK YOU!
static808 is offline   Reply With Quote
Old 08-16-2006, 07:21 PM   #2
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Congratulations on the decision. You will fall in love with the Yaris very quickly (if not already)!
The ride quality is improved after lowering it with the Eibach Pro Kit springs, which are provided by Toyota, named as "Lowering Springs" on their catalogue.
There is a lower center of gravity, and your vehicle will feel better during general commuting, and the turns will feel more solid.
I vigorously test drove a stock Yaris, and I did not like the feeling I got from it during exits and entrances to highways and ramps. You will feel much more comfortable with a lower ride height on the highway.
It's worth noting that the stock ride height is 4", and the Eibach Pro Kit will lower the vehicle approximately 1.5".
Hope this helps your decision.
Good luck!
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 08-16-2006, 08:25 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
I am lowered with Tanbe DF210's with stock shocks. My overall loss was 2" lower all around, still with the stock 15" steel wheels.
My car is my everyday commuter only, and it still drives like stock. Once pushed in tight turns, on/off ramps, quick lane changes etc., the car is a whole new animal! Very firm, very flat, and very controlled.
Old 08-16-2006, 09:11 PM   #4
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
i can say the same as christ i have the df210.. think im going to make lapping with the car to really feel it ;p
OxyG3nE is offline   Reply With Quote
Old 08-17-2006, 12:09 AM   #5
johnnyfive
johnnyfive's Avatar
when did chris get the holy status :)
by the way, my sedan with the DF210's is much noticably ruffer over poor road surfaces, as will be the side effect of any suspension work that gives you more stability and controle of the car. It is all about acceptable comprimise with both aspects of driving.
for me the slightly rougher ride of the DF210 is more than acceptable for the controle it gives, but i can not speak for the TRD springs, but a general rule of thumb, the less the drop(less change from stock spring rates) the less you will notice the changes in handeling, and driving comfort :)
johnnyfive is offline   Reply With Quote
Old 08-17-2006, 08:33 AM   #6
Chris07LB
Chris07LB's Avatar
You didn't hear?
Old 08-17-2006, 03:04 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Johnny,
Do you notice any issues when pulling over the parking lot blocks since you have dropped? I know that the ones that are around here (which should be the same everywhere) just fit under the front lip with stock suspension.
Old 08-16-2006, 09:22 PM   #8
static808
static808's Avatar
thanks for the quick responses everyone! after reading some more threads on this forum, i think we will definitely get the lowering springs. we would love to get the shocks as well, but then this car wouldn't be as "economical" as we'd like (pretty BIG reason for getting the car!), since we want the power package and the side airbags as well. once again, thanks everyone for the input!
--B
Old 08-17-2006, 11:08 AM   #9
Carvin'07
Selling all mods
Carvin'07's Avatar
Drives: '07 Bayou Blue - totally stock
Cool
I think the TRD springs are 'ok'. They are fine for comfortable sport cruising and the occasional fast turn, but don't expect racecar-like handling. There is still some bodyroll. It is quite comfortable.
The stock struts/shocks are 'ok' as well. The rears handle the lowering much better than the fronts. IMHO, the stock front struts are underdamped for the TRD springs.
Carvin'07 is offline   Reply With Quote
Old 08-17-2006, 11:12 AM   #10
Carvin'07
Selling all mods
Carvin'07's Avatar
Tires were the big noise enhancer. No change on the springs only.
Old 08-17-2006, 11:35 AM   #11
Chris07LB
Chris07LB's Avatar
Same here..
Old 08-17-2006, 01:02 PM   #12
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Any problems scraping the ground?
Old 08-17-2006, 01:43 PM   #13
Chris07LB
Chris07LB's Avatar
Nope, never! I drive some pretty ghetto roads up around North Jersey too..
Old 08-17-2006, 02:57 PM   #14
JustAnotherAsian
now in HD
Drives: not yaris!
Send a message via AIM to JustAnotherAsian
with overhangs that barely extend from the wheel, i'd also expect that- especially from the rear. even with a low drop, the departure angle in the rear is still ridiculously high- kudos to yaris liftbacks! lol.
JustAnotherAsian is offline   Reply With Quote
Old 08-17-2006, 01:05 PM   #15
Carvin'07
Selling all mods
Carvin'07's Avatar
No scraping whatsoever. I live 7 kms/4.7 mi in the country on rutted and bumpy gravel roads. Speedbumps are no problem, but I have a relatively mild drop.
Old 08-17-2006, 06:31 PM   #16
jah
jah's Avatar
Drives: Hatch
I have the TRD shocks/springs:
http://www.yarisworld.com/forums/showthread.php?t=818
The ride is alot firmer, before when I went over a couple highway expansion joints at 70+MPH it had a couple of bounce oscillations before it settled down. Now its one very firm jolt, not bad, but noticably firmer, no bounce. Still has a bit of body sway, but still have the stock 15" steel rim/tire combo.
As far as clearance, I will scrape at the bottom of my drive, and a couple of places going to work if I don't slow down Additionally, it will scrape some of the parking blocks around here
Bottomline, my hatch is a commuter, mostly highway, and the TRD shock/supsension is a great improvement IMHO
jah is offline   Reply With Quote
Old 08-26-2006, 03:22 AM   #17
Lafiro
Drives: 06 Yaris Sedan
Im getting a lot done tomorrow.
Im getting my TRD Sportivo lowering springs installed. HID's installed. And 2 12" subs installed in a custom made box.
And tuesday, im most likely going to get my rims/tires.
Wish me luck, I will post before and after pictures when I can!
Old 08-26-2006, 01:51 PM   #18
static808
static808's Avatar
we wish you well! definitely take some interior and exterior shots! curious how the subs integrate into the trunk, since they're not the largest trunks. oooh, and tell me about the ride with the new lowering springs!
--B
TRD OR Eibach...i'm confused... hoahmaru Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 11-07-2008 09:25 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 01:40 PM
FS: Spirit Lowering Springs 1.7" drop xCookiE Items for Sale by private party 2 07-24-2006 09:29 PM
TRD Lowering Springs DJ_Trizzak Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-06-2006 12:20 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 09:30 AM
