Old 12-07-2008, 03:12 AM   #1
onizuka
Drives: Yaris Blk 5 Drs RS
Yes, ABS and handbrake lights are on. Meaning that your ABS is inactive.
Been there, done that last year. Speed sensor is defective. If I'm getting the same problem again due to cold/snowy weather, this proves that the car is poorly handling our Canadian winter.
onizuka is offline   Reply With Quote
Old 12-07-2008, 10:27 AM   #2
Pars
Drives: 07 Yaris Liftback
Actually, the car handles great in the snow, without the ABS. I put on about 20,000km last winter, with ABS light on...(not working). Having the ABS would have been nice, but the little car still has good balance, all it needs is a good set of snow tires. In fact, I think the Yaris's ABS system shines when the road is dry, in the snow, it tends to over react.
Pars is offline   Reply With Quote
Old 10-13-2011, 03:03 AM   #3
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Momentarily had this a few months ago. I suspected the VSS, couldn't prove it. Handbrake definitely was not dragging, my car free-rolled without issue.
Just another nail in the coffin proving my theory that the Yaris is the furthest thing ever from the reliable Echo...
derickveliz2:
I was under the impression the hub had to be removed to access these wires. Yay or nay?
firemachine69 is offline   Reply With Quote
Old 10-13-2011, 11:40 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
No they don't. I did someone's brakes on their Yaris and cleaned and packed the connectors as preventative maintenance.
You need a small screwdriver or something to help get the clip off if I'm not mistaken. It was a while ago now.
Old 10-14-2011, 03:45 PM   #5
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
derickveliz2:
Yes and No... It helps to fix them if you remove the hub, but 1 side had 2 wires broken all ready like you see in the pictures above, the other side only one wire was broken. I did remove them both. no access to the wires from the inside of the hubs, it's where the wires go into the hub. I hope I didn't confuse you?
Originally Posted by Bluevitz-rs View Post
N
You need to squish the little tongue on the lower part of the hub.
"NO MORE LIGHTS FOR ME!!! and I spend nothing but my time. Lets see when they will turn on again!
D.
CLA 250, 4MATIC
