Old 12-11-2008, 11:15 AM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
when i asked the dealer they said 5w30 and only 5w30
mikenacarato is offline   Reply With Quote
Old 12-11-2008, 11:23 AM   #2
superfly78209
Drives: 2010 Yaris 5 Dr Blue Grey
even 5w30 in the winter?
superfly78209 is offline   Reply With Quote
Old 12-12-2008, 08:26 PM   #3
SilverGlow
Drives: 2007 Yaris Hatchback
My dealer showed me a TSB (published by Toyota) and he told me to use 5w-20 only, regardless of what the manual says, and regardless of what is printed on my valve cover cap.
SilverGlow is offline   Reply With Quote
Old 12-13-2008, 10:01 AM   #4
1stToyota
1stToyota's Avatar
And regardless of what that Toyota TSB actually says?
It clearly states that 5w-20 is fine to use now, but the note at the top of the TSB says to stick with what's listed in the service manuals, owner's manual and oil cap, which happens to be 5w-30.
Looks like the dealer drew his own conclusions about what's best, just like you did when you started using and recommending Yaris owners to use 0w-20 because of UOAs for non-Yaris motors, and because the TSB said 0w-20 was okay to use in a Corolla, Scion XD, etc...but if I can read between the lines I'm guessing that you drained out the 0w-20 and took the dealer's advice about the 5w-20.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 12-16-2008, 01:42 PM   #5
SilverGlow
Nope, I'm still running 0w-20 because I know that at operational temps 0w-20 and 5w-20 provide the SAME protection. And the UOA's I've seen are for Yaris SPECIFICLY.
I have the TSB in front of me and it says that the Yaris engine can use the 20 weight. So where is the confusion? Where is the ambiguity?
It's very, very clear. If you have a Yaris, you can use 20 weight safely, and Toyota is behind what I wrote.
And if you look at the AMSOIL site (and Mobil1 too), you too will see that their 0w-20 can be used in ANY MOTOR that is spec'd for 5w-20. Safely.
So is your beloved AMSOIL wrong? Not!
Old 12-17-2008, 08:40 AM   #6
1stToyota
1stToyota's Avatar
Then quit quoting the Toyota TSB and acting like you know something if you're going to continue using a viscosity that the TSB says is NOT to be used in the Yaris 1NZ-FE motor.
It doesn't say to use straight 20 weight, it doesn't say to use 0w-20, it says 5w-20
Absolutely false...it never, never says that 0w-20 is to be used, you're confusing the 0w-20 being okay for a Corolla and the XD, etc... and 5w-20 being okay for the Yaris.
But that contradicts the guidelines of Toyota's TSB, and that's what Toyota will go by, what their TSB states, not AMSOIL's override.
Check my sig. Not using AMSOIL anymore because to get API approval ACEA A1/B1 is what I get, with no API approval I can get A5/B5, but if I ever have any warranty issues I want an oil that is API approved....and better than A1/B1 for my own reasons.
And they are wrong when their statements clash with Toyota's TSB guidelines, and still have to wonder why you're soooo worried about 0w-20 when you live in southern Ca that wouldn't know what a real winter was.
2008 Scion xD
NEW PRODUCT! SIMOTA DROP-IN REPLACEMENT FILTERS kargoboy YarisUniverse 10 01-21-2009 08:48 AM
Drop in performance air filters which is best? YarisSedan Performance Modifications 14 11-07-2008 09:52 PM
SRI or CAI YogiYaris Performance Modifications 21 05-03-2007 11:28 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Darn Workplace Internet Filters...! Yaris Revenge Off-topic / Other Cars / Everything else Discussions 18 08-01-2006 08:30 PM
