#19 |
![]() ![]() Drives: 07 Yaris LB, 93 Camaro Join Date: Aug 2007
4 MPG, where are you in MO? if you are near the St. Louis region I would go for a ride with you and give you some pointers if you would like. I am not the best out there by any means, but I have averaged 42.7 in an automatic for the lifetime of the car (1.5 years, almost 22,000 miles)
oh, and with recent drops in gasoline prices, the E10 mandate could go by the wayside. MO state law only mandates the E10 blend when ethanol is cheaper than gasoline. this is no longer the case, I have not heard of any changes, but it could happen. (however if you live in the St. Louis metro, this won't help because we have required E10 for years to keep the air clean) you'd probably be shocked at how much less MPG you get when the temp drops to below freezing
-Aaron ![]() |
#20 | |
![]() Drives: black 5spd hatch yaris Join Date: Dec 2008
I just filled up (3.x gallons lol) of all city driving and I got 35.5x MPG... so I am acutally getting better MPG with all city driving than with city/highway mix. |
#21 | |
![]() Drives: 2007 Yaris Sedan Join Date: Sep 2007
Your exaggerations are comical at best. Not sure how one going above minimum speed and below maximum speed limits could "cause" a crash. But I'm sure you'll convince yourself that you can find fault in there somewhere. Go ahead. I'd prefer to blame it on the inattentive speeding drivers who are 'just trying to keep up'. |
#22 |
Albino truck smasher
Drives: '07 Yaris LB Auto Join Date: Oct 2008
Dropping your speed and going light on the gas is about the best thing you can do at this point, as well as pumping up your tires and installing a grill block.
I used to complain about getting between 34-37mpg while driving at around 70-80mph, and only once I dropped down to 60mph did I notice a significant difference in my MPG. If I can drive 50mph on the California 110, I-5 and 405 during rush hour, which are some of the fastest-moving, most congested and aggressive roads on the US, I am sure you could drop your speed down a notch. The whole point of driving "well" and economically is being aware of what is occurring around you. Pay attention to those behind you and you should be fine. |
#23 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
lol..Yes, I totally believe you. Over here I've duct taped to the top grill and taken off the airbox snorkel.
#24 | |
I think the next step for me is to try it around 65 MPH with the "pulse/glide" style method described in the stickys, and forget the cruise control. I can defiantly see how it would kill MPG after reading what loren was saying. However, I did try it at 60 MPH for 3 days, and I only went up to 39.8x MPG. I would have expected more at 60 MPH using the DFCO/gliding methods? Or is the CC really killing it that bad. Last edited by 4MPG; 12-13-2008 at 04:17 PM. |
#25 | |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
#26 | |
![]() Drives: 2008 Toyota Yaris, automatic Join Date: Oct 2008
#27 |
Come over to a real city where we have more than 2 lanes.
#28 |
#29 |
I thought so, but apparently he has an affinity to terrible drivers and getting run over.
#30 |
![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
Hahahaha! Well, I for one am learning to love going slower... Although I do maintain the legal speed limit (70 on the interstate here), I go no faster and try to adhere to 60 or lower on other roads; am also getting in the habit of coasting when possible and shifting into neutral when stopped at lights. I expect great mileage readings now that I'm out of third gear... Stay tuned!
#31 |
![]() ![]() ![]() Drives: '09 Yaris 3dr, 13 F150rcsb 5.0 Join Date: Oct 2008
Filling with such a small amount puts way too much importance on the consistency of the fill itself (ie, which way the car was parked - up or down angle, how sensitive the shut off was, any air in the filler/tank, temperature...etc.).
#32 |
![]() Drives: 2008 Liftback AT Join Date: Dec 2008
CC = Bad FE
Cruise Control is bad for fuel economy. With the CC going the engine, in my opinion, overreacts hills. You'll get much better FE if you just try to keep the gas pedal in the same position most of the time. This is made very easy with the scangauge.
For all those who are unhappy with the fuel economy of the Yaris, if you saw the last episode of Top Gear, on their track they managed to get 17 mpg out of a Prius. They came to the conclusion that it is all about the way you drive.
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 04:23 PM |
| Toyota Yaris achieves over 84 mpg in MPG Marathon | tk-421 | Off-topic / Other Cars / Everything else Discussions | 5 | 11-17-2008 07:41 PM |
| Toyota Yaris MPG Review at www.mpgomatic.com | aca72 | Fuel Economy Forum | 23 | 10-31-2008 03:59 PM |
| Wow, I Got 48.57 mpg | Kaotic Lazagna | General Yaris / Vitz Discussion | 52 | 05-10-2007 10:09 PM |
