Old 12-22-2008, 03:41 PM   #1
gid
It's called driving slower when you are in a known trouble area. I am surprised that you were not smart enough to figure that out for yourself.
you take the cake .
Old 12-22-2008, 03:48 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by gid View Post
you take the cake .
Yeah. Thats why i just stopped responding to his post and future posts. Some people will belive they are right no matter what evidence you bring up to prove they are wrong. And they will try to find a flaw in everything you say to them or use as evidence in order to keep saying they are right. Its just a waste of time those type of poeple can not be reasoned with.
Old 12-22-2008, 05:20 PM   #3
Pitt Yaris
Drives: Flint Mica Sedan
What ? PLAN AHEAD ! There's no planning for a deer that decides to bolt out in front or into the side of your vehicle from over an embankment or from thick brush / wooded area . This has to be the dumbest ( ) thing stated on this topic so far .
I agree with these comments 100%. Can't believe some people's logic. I guess some posters are one with nature....
Old 12-22-2008, 03:58 PM   #4
YarisSedan
Here are some reputible, reliable sources of information that will tell you all you would ever want and need to know about tires and tire pressure to put this post to rest. If the quotes interest you click on the link to read the complete articles
http://www.betiresmart.ca/resources/...oc2=faqs#faq03
"Is over-inflation harmful?
Yes. One of the biggest tire maintenance-related myths is that over-inflation is not a problem. Often, even people who understand that under-inflation is a problem are unaware of the harmful effects of over-inflation.
An over-inflated tire rides on just the centre portion of the tread. The smaller contact area means reduced grip on the road leading to a harsh ride, handling issues (such as steering and stopping problems) and increased wear on tires and suspension components.
What should I do if my tires are over-inflated?
If you find that your tires are over-inflated, release air by pushing on the metal stem in the center of the valve, then re-measure the pressure. Never reduce pressure when tires are hot. Wait until they are cold, meaning that your vehicle has been stationary for at least 3 hours or has not been driven more than 2 km."
http://www.popularmechanics.com/blog...s/4199963.html
"Debunking a Mileage Myth: Can You Really "Pump Up" Your Fuel ..."
http://www.tirestamp.com/index.php?o...139&Itemid=177
"Question: Is my tread wear effected by overinflation?
Answer: Overinflation is almost as bad as underinflation. Overinflation is any pressure that exceeds the pressure needed to carry the load by 10% or more. Just as with underinflation, overinflation changes the footprint too. The contact patch actually becomes shorter and narrower. This results in the shoulders of the tire scuffing along while only the center of the tire makes full contact with the road which leads to irregular wear patterns and lost tread mileage. Center rib wear, flaking, chunking, erratic depression wear are commonly observed conditions in addition to overall rapid tread wear. A tire that is overinflated by 20% will lose 10% of its tread mileage. In addition, traction is negatively impacted since the contact patch is much smaller than is optimal. The ride is harsher since the sidewall is much stiffer and handling is different since the footprint has changed. Vehicle suspension and steering system components are also affected by the harsher ride and handling due to over inflation. Overinflated tires are also prone to cuts and snags, impact breaks, and sidewall and crown penetrations affect a vehicle’s handling. "
Old 01-30-2009, 04:32 PM   #5
SilverGlow
Drives: 2007 Yaris Hatchback
Those links you reference are mostly bool sheet.
And in fact, I have my tires all pumped up at 45 PSI, and:
(1) My milage is about 12% higher.
(2) My tires are wearing EVENLY across the thread. Center of tire shows EXACTLY THE SAME as the shoulders of all tires.
(3) My tires are about 80% worn, and after 52,000 miles. At that rate I should get at least 65,000 before I the wear indicators show.
(4) The degration in handling and grip is INSIGNIFICANT.
So you see, you can't always believe everything you read on those "expert" sites.
SilverGlow is offline   Reply With Quote
Old 01-30-2009, 05:40 PM   #6
1stToyota
1stToyota's Avatar
12% higher? That seems like a pretty good number for you...I think that's about what the Lucas f.i. cleaner did for you.
And if your tires are 80% worn, grip and handling are already WAY down from what it was when your tires had 50+% tread left on them. Most tire *experts* believe in the Washington's head rule now instead of the old Lincoln's head rule. Stopping distance for the latter can be up to twice the distance.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 12-22-2008, 04:13 PM   #7
gid
we've had deer dart out from between homes within city limits during daylight hours . So you can't always be prepared MR.PERFECTO . The deer are running out of habitat and with the warmer climate of recent years there's been a population explotion . Therefore they're more active in the day looking for food . MAYBE YOU SHOULD EXPLAIN THAT TO THE DEER HERE AND EVERYWHERE .
Old 12-22-2008, 04:21 PM   #8
gid
Y.S. , he sent me a private message telling me to remove a post I made in one of his THREADS . He wants all the glory . To think these are the people who are MODERATORS and use it as leverage and attack other members with insults . Reminds of a certain ADMINISTARTION for the past 8 years .
Old 12-22-2008, 04:39 PM   #9
1stToyota
1stToyota's Avatar
If over-inflation wasn't ONLY about increased fuel economy, we'd be seeing actual real world test results with handling, braking, etc..., comparing the results of tires that have normal pressure with those with double pressure, not just fuel economy increases, or do the 60p.s.i.ers and the websites they go to consider *safe* being a tire that didn't blow out? I'd like to see some real test results of two cars being track test against each other. I'm betting the car with over-inflated will come in 2nd in every catagory except fuel economy.
2008 Scion xD
Old 12-22-2008, 04:47 PM   #10
YarisSedan
Old 01-30-2009, 03:53 PM   #11
SeaYa
Is about to 'SeaYa' later
SeaYa's Avatar
Drives: 08 MT Sedan
Thank you! I tried something like this! Snowy parking lot (1-2 inches) and brought my pump. Did 30 psi and 45 psi two times each on a 20 mph turn in the middle of the lot. Here's what happened: 30psi, better traction, worse handling. I slid about 7 feet from my intended line of travel with the car pointed to the outside of the turn. At 45 psi, I had worse traction, but better handling. I slid nearly 12 feet from the intended line of travel, but the car was pointing nearly straight on the way I wanted to go. Did some reading and thinking and maybe this is why: The Yaris is a very light FF, and with an empty trunk, any increases in tire pressure will have a more dramatic effect on the rear tires, eg, smaller contact patch. Since there is already so little weight back there, the rear tires slip to an even greater degree than the front when at 45 psi, hence, the back sliding around more cuts down on the under steer, and you get the feel of better handling. Traction though, another story, I slid 5 extra feet off the 'road', which in straight line braking, could mean running into the hazard you were "looking ahead for and planning for, but still hit because I sacrificed my vehicles engineered performance for an extra 2 MPG"..and by the way, to all the 60psi people...I can't find your actual MPG savings on this post.
To the OP: I've done 35psi (42/44mpg) and 40psi (42/ 47mpg).
Seems to me like the hypermilers are trying to beat the EPA rating by as much as possible for bragging rights. Otherwise, why stop at 60? Why not do 100psi? If your answer is because the tire will burst, then you admit to already pushing the engineered limits of your tire. Otherwise, if traction isn't important to you, why not buy 3 extra spares and run them at 80psi? They're only rated for 60psi, but you don't seem to have a problem with doubling manufacturer recomendations. Let me know how that works out for you.
Last edited by SeaYa; 01-30-2009 at 06:21 PM. Reason: My god, I actually mistyped FR instead of FF...for shame, for shame
SeaYa is offline   Reply With Quote
Old 01-30-2009, 05:46 PM   #12
1stToyota
1stToyota's Avatar
Originally Posted by SeaYa View Post
Thank you! I tried something like this! Snowy parking lot (1-2 inches) and brought my pump. Did 30 psi and 45 psi two times each on a 20 mph turn in the middle of the lot. Here's what happened: 30psi, better traction, worse handling. I slid about 7 feet from my intended line of travel with the car pointed to the outside of the turn. At 45 psi, I had worse traction, but better handling. I slid nearly 12 feet from the intended line of travel, but the car was pointing nearly straight on the way I wanted to go. Did some reading and thinking and maybe this is why: The Yaris is a very light FR, and with an empty trunk, any increases in tire pressure will have a more dramatic effect on the rear tires, eg, smaller contact patch. Since there is already so little weight back there, the rear tires slip to an even greater degree than the front when at 45 psi, hence, the back sliding around more cuts down on the under steer, and you get the feel of better handling. Traction though, another story, I slid 5 extra feet off the 'road', which in straight line braking, could mean running into the hazard you were "looking ahead for and planning for, but still hit because I sacrificed my vehicles engineered performance for an extra 2 MPG"..and by the way, to all the 60psi people...I can't find your actual MPG savings on this post.
Good rule of thumb for them is to just throw their gauges away and air the tires up until they resemble motorcycle tires...bet their cars will corner better with a little bit of body-english.
2008 Scion xD
Old 12-22-2008, 05:39 PM   #13
b_hickman11
Drives: 08 Sedan
Actually I have a true story about a deer...kind off topic but it shows how deer are in my area. I used to work in a grocery store in high school and I was sacking some groceries on the front end one day. All of a sudden a lady comes runnning in the door screaming bloody murder. She runs towards the back of the store. Well right behind her was a 2 pt buck running into the store also. It ran over to the produce and 2 customers(2 huge guys) tackled it and tied it up. We sold deer corn at the store and kept the bags out on the sidewalk. 2 deer smelt it and came up there to eat it. Then they got spooked and 1 took off back towards the woods. The other one ran towards the door and well you know the rest of the story.
Old 01-21-2009, 01:49 PM   #14
MadMax
MadMax's Avatar
I don't know why anyone would bother arguing with these "hypermilers," the bottom line is that they are right and the rest of the world is wrong!
I really wonder why these people don't drive a Prius? If they are so dedicated to getting the maximum efficiency out of every drop of gas, then they should select the proper equipment to do so. A Prius with 60+ PSI in it tires and employing those "hypermiler" techniques could get about a bazillion gallons to the mile!
And to my friend in Nacadoches, we both know the dangers of deer in Texas. Maybe we are too stupid not to "plan ahead," or maybe the deer just aren't following the rules! I will ask the next time I see one...
Cheers! M2
Old 01-21-2009, 04:51 PM   #15
33OH
Drives: '08 Yaris
I actually used to run 50 psi in my tires just for MPG reasons. And then I hit a deer because I couldn't stop fast enough. Slammed on the brakes and the car just skidded on the road, hardly gripping at all.
Bottom line? I run 32 psi now, what Toyota recommends. Only took $5,000 and the safety of me and my passenger to figure it out.
Old 01-21-2009, 05:46 PM   #16
MadMax
MadMax's Avatar
ryank, what the hell, didn't you PLAN AHEAD?!?
But I am going to see for myself. I just aired up my tires to 40 PSI (my tire pressure sensor light just went off this morning, so I had to check the pressure anyway) and we'll see how it goes. I sure hope I don't find out the hard way that this is a bad decision...
By the way, what is the PSI level that kicks off the air pressure sensor light? All my tires, sans one, were at 32 PSI; and the one that was a bit lower was only 28 PSI. Seems kinda high for the sensors to kick off...
Cheers! M2
Old 01-22-2009, 08:12 AM   #17
33OH
Drives: '08 Yaris
Thanks for the laugh
But in all seriousness, if anyone thinks they can avoid an "accident", they're called that for a reason.
Old 01-30-2009, 04:24 PM   #18
otterhere
Drives: 2008 Yaris 3-door Meteorite
Hmmm; wonder why mine didn't go off? All four tires were at the same LOW level (26) when I finally checked them; with it increased to 38 -- didn't quite go to 40 -- I'm expecting better mileage the next time I check the MPGs...
otterhere is offline   Reply With Quote
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 10:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 12:37 PM
