Old 01-23-2007, 12:27 AM   #1
KittenRD
KittenRD's Avatar
Drives: Metallic Meteorite Liftback
Send a message via AIM to KittenRD
Tire Pressure and Gas Economy
I am sure this has been in the forum at one point... Can someone link me to it? Anyway, I was wondering what tire pressure would give the best gas milage in the LB? Thanks.
KittenRD is offline   Reply With Quote
Old 01-23-2007, 01:26 PM   #2
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
You have to choose the pressure that Toyota mentions in the manual.
For mine it is 30psi.
Old 01-23-2007, 03:15 PM   #3
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Actually I would say 2 pounds over on each tire,because youll have less rolling resistance,and save gas,and over time you will leak air,so they will be more correct in a week.This is the way to go.
eco is offline   Reply With Quote
Old 01-23-2007, 03:50 PM   #4
fearturtle44
Drives: S Flint Mica
The best tire pressure is the number located either in your manual or inside the drivers's door on side panel. I think for the 4 door, it is 32PSI.
Kevin
fearturtle44 is offline   Reply With Quote
Old 01-23-2007, 03:53 PM   #5
Katana
Katana's Avatar
Yes 32psi is the correct number.
Last week, I forgot to lower the tyre pressure after a trackday and I went to check it.Oh my God, it was 50psi!The car's handling was awful and it was oversteering all time long!Hahaha
Old 01-23-2007, 05:26 PM   #6
swng
swng's Avatar
Drives: 06 3-dr auto RS
The Fuel Economy Thread will always welcome you. If you search the forum for "tire pressure", that thread will come up amongst others. Then, you can stroll through it and the words "tire pressure" will appear in red whenever you come across them.
It is a 64-page thread as at today. Enjoy!
swng is offline   Reply With Quote
Old 01-24-2007, 11:04 PM   #7
KittenRD
KittenRD's Avatar
Thanks all. I know with my parents' priuses, the best tire pressure is higher than the one in the manual.
Old 01-24-2007, 11:06 PM   #8
KittenRD
KittenRD's Avatar
That isn't always the best for gas economy though. The gas milage improves with pressure greater than recommended for my parents' priuses. The type of tire also effects the gas economy as well. Certain tired only give 41 and others give 55. There is a big difference.
Old 01-24-2007, 11:08 PM   #9
KittenRD
KittenRD's Avatar
Thanks a ton!
Old 01-25-2007, 12:13 AM   #10
Black Yaris
der Zeck
Black Yaris's Avatar
Hey kitten, always go with the vehicle manifacture's set air pressure, in our case 32. This is where you want it for everday driving, and try Nitrogen in your tires as well, it helps keep a more constant air pressure inturn giving better gas mileage
Old 01-25-2007, 09:47 PM   #11
KittenRD
KittenRD's Avatar
Thanks I knew about the nitrogen. That is what my parents use in their cars I believe. Though they also use a higher tire pressure than the manual says to improve gas milage.
Old 01-25-2007, 10:54 PM   #12
Black Yaris
der Zeck
higher pressure =better MPG, but more$$$ in tires, because they wear out faster
Tire Pressure & Fuel Economy enkid General Yaris / Vitz Discussion 7 12-05-2006 02:48 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
