#55 |
Drives: 2009 Yaris liftback Join Date: Nov 2008
Right but SilverGlow is in SoCal.
#56 |
And he's never seen a snow flake or an ice storm in southern Ca, but he insists on using 0w-20??
#57 |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
I am using Mobil-1 AFE (green cap) 0W-20 in my 2009 Honda Fit. The cap calls for 5W-20 so that's fine.
I am using AFE (green cap) 0W-30 in my 2007 Yaris. I don't think I'm going to go to 0W-20 eventhough the TSB says you can. The TSB is a little ambiguous. I always use a Napa Gold (Wix) oil filter. They are awesome and not overpriced.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#58 | |
0w-20 and 5w-20 grades only get a ACEA A1 rating, but the 5w-30 gets a ACEA A5/B5 rating that matches the Amsoil HP 5w-30 that I'm now using, but with the PP I'll feel a little better with the API approval on the front label. |
#59 |
![]() ![]() Drives: '08 HB Join Date: Nov 2008
#60 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
I went and priced some at ADAP (wal-mart was out of stock of all 5w20) and for castrol and Mobil synthetic they were $7.69 + 6.5% tax and Pennzoil platinum was 8.09 + 6.5% tax craziness..... |
#61 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
exist in the public domain. You are making up data (74% of alll statistice are made up on the spot). Plus it doesn't matter, Our engine failed. My neighbors Rav4 has a bad engine rap also. He put QS higher milage in it and it didn't quiet it. BTW Silver, you have no credibility here amoungst educated adults. VW/porsche/Audi I suppose are the only ones smart enough to spec the A3/B3. signed: +/-3 sigma |
#62 | |
Just my dos centavos Last edited by TheSilkySmooth; 12-17-2008 at 12:48 PM. Reason: misspell GID as God he may be nice but not that GOOD ... |
#63 |
No way am I putting PP in my oil! Urine has poor lubricating properties.
#64 | |
After researching LubroMoly I noticed the 5w-30 had good specs, but was a syn blend and not API approved, so I bought a case of LUCAS thinking it was API approved. Not using it in my Yaris, but already sold 6 of them to a guy in a Chevy SS Impala. After too much thinking on what'd be best overall, made up my mind on Pennzoil Platinum for it's good UOAs, API appoval, ACEA A5/B5 ...I know the AMSOIL HP probably wasn't API approved because it exceeded the API rating, but for safety's sake I'll make the switch to PP. Number's wise, looks good, but I'll let you know. After running the AMSOIL for 5K, I'll see if I notice anything strange happening with the PP. |
#65 | |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
5w-20 only for the YARIS ...
#66 |
had tried the 5w-20 for the liftback and could hear a whining noise at highway speeds so drained the 5w-20 ( PENNZOIL Platinum ) and installed the 5w-30 using SHELL full synthetic . Now , no noise . Timing chain , other ?
#67 | |
SIPNDEW
#68 | |
So what was your reasoning for putting 5-20 in the car? |
#69 |
better flow for colder weather ...
#70 |
Ok, so I will be buying oil in a few hours when I wake up.
But as for Wix and other oil filters, I see two or three part numbers. Can someone please tell me a few "good/excellent" oil filters for use with probably royal purple on my yaris sedan with the part number next to it. This way I can buy it and change the oil myself at my friends shop. Then I will reset the maint Req light and end that for the next few thousand miles. Thank you everyone. |
#71 |
#72 | |
you not being rude ...
| NEW PRODUCT! SIMOTA DROP-IN REPLACEMENT FILTERS | kargoboy | YarisUniverse | 10 | 01-21-2009 08:48 AM |
| Drop in performance air filters which is best? | YarisSedan | Performance Modifications | 14 | 11-07-2008 09:52 PM |
| SRI or CAI | YogiYaris | Performance Modifications | 21 | 05-03-2007 11:28 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 08:37 PM |
| Darn Workplace Internet Filters...! | Yaris Revenge | Off-topic / Other Cars / Everything else Discussions | 18 | 08-01-2006 08:30 PM |
