Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Europe (continental)
Old 12-29-2008, 06:32 AM   #11
Homeboy
Homeboy's Avatar
Drives: Toyota Yaris XP9
Originally Posted by Nico4960 View Post
You want to change for "40mm lowering" be carreful in Belgium you cannot exceed 30mm for lowering springs... If you want more, you must take adjustable suspension...!
Nico, just 1 small question: why is lowering of -40mm a problem? I know that if you go lower than 40mm, you need adapted shocks. A coilover kit is always the best way to lower a car, but here in Belgium, you have the choice between KW and H&R (because of the paperwork we need for GOCA). But they cost minimum 1400 EUR (without placing costs). A bit expensive, compared to lowering springs only.
Therefore, if we can order several coilover kits together, the price might drop a bit...
If not, i will go for lowering springs only.
Yaris XP9 'by Sparco'
Homeboy is offline   Reply With Quote
