Old 01-11-2009, 02:58 AM   #6
Hmmm get your power from the 12V and Ground lines, and add a relay that is normally closed, controlled by the Accessory line. That way, the circuit is only complete when the accessory power is off. You can find these cables in the ignition switch wiring, take a look at one of the stickies here with the wiring information:
http://www.yarisworld.com/forums/showthread.php?t=12220
