#1 | |
What?
Nah, I'm not smart, I've just studied suspension tuning a little bit. Motion ratio is a pretty fundamental concept to calculating proper spring rates. The "wheel rate" is what matters, the effect of the spring "where the rubber meets the road". The rate of the actual spring is irrelevant.
^ Yes, but thank you
![]() ![]() Drives: white and red shiny things Join Date: Jan 2009
Ooh I hate that bobbing / thumping / bouncing sensation!!!
What?
Not necessarily all the same problem, though.
Bobbing = underdamped Thumping = bottoming due to insufficient suspension travel OR really stiff damping Bouncing = underdamped Typical "lowering springs" on stock shocks will often cause all of the above. The spring rate is enough that they're underdamped on stock shocks, and they typically reduce ride height too much for the spring rate allowing the suspension to bottom out. |
i was talking with my friend who races his mr2 competitively....we worked it out to about 370lb front and 550lb for an ideal-ish racing setup with street tires....but thats assuming 60/40 weight distribution....
the calculations went as follows: take half the weight of the car and multiply it by the opposite distribution expressed as a percentange. so front is 1150 x 0.4 = 460 then multiply that by the generalized gripping ability of your tires....r comps = 1, summer tires maybe 0.8....but its all a generalization so 460 x 0.8 =~ 370lbf/in rears are 1150 x 0.6 x 0.8 =~ 550lbf/in you want to have the rears in a fwd about 150% of the fronts.... also in discussion was that of a rear sway bar....we surmised that if you have a rear sway bar you can go with a more livable rear rate (say 450 or 500) as the rsb stiffens the rear under cornering load so the rear doesnt need to be as firm there are lots of items to consider when tuning a suspension...more than just spring rates....but i guess that calc can give you a pretty good idea of whats req'd but ill be on megan coils in spring with are 5kg fron and 6kg rear (or 280lb front and 335lb rear)
What?
His generalized calculation is most likely going to give you a general WHEEL rate. Don't forget to include the motion ration in the equation, which means the rear rates need to even higher.
#8 | |
im not honestly GREAT w/ suspension items, but im learning slowly...
#9 | |
What?
So, for instance, if you had 6" of travel at the hub, and 5.25" of travel at the spring, 5.25/6.00 = .875 Now, if you're looking for a wheel rate of 500#, you'd DIVIDE that by the motion ratio, 500/0.875 = 571 ALL OF THE ABOVE NUMBERS ARE JUST FOR DEMONSTRATION PURPOSES, THEY ARE NOT ACCURATE... THEY'RE NOT EVEN GUESSES. (I know how stuff posted on forums can take on a life of it's own, just thought I'd add that) |
What?
Engineering is not for the timid.
What?
I know you guys are just goofing around, but a serious question was asked and serious answers were given... this kind of response does not inspire people to want to take the time to post serious answers.
yeah, you're right, trying to keep the mood light but this is a very educational thread
Wow! This thread is a awesome. I'm thinking about getting coilovers, and this has taught me alot about what I should be looking for. Lots of good info here. As usual....Loren brings it. THANKS LOREN!!
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
| Where can i buy a lowering kit and spring 4 toyota yaris S sedan (4 doors) | mariosuper | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 07-07-2006 09:06 PM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
