Old 01-23-2009, 10:50 PM   #1
Originally Posted by Loren View Post
His generalized calculation is most likely going to give you a general WHEEL rate. Don't forget to include the motion ration in the equation, which means the rear rates need to even higher.
ah yes, thats what i forgot to add....so thatd maybe bump up the rears 50lb?
im not honestly GREAT w/ suspension items, but im learning slowly...
Old 01-23-2009, 11:19 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
To answer that question reliably, someone would have to measure the motion ratio. Easy enough to do with the spring removed and the car on jackstands. Put a jack under the hub and lower it as far as it will go. That's your zero point, take a reference measurement from the ground for both the hub and the lower spring perch. Then raise the hub as high as you can and take both measurements again. Subtract the before and after measurements and compare the result, that's your ratio.
So, for instance, if you had 6" of travel at the hub, and 5.25" of travel at the spring, 5.25/6.00 = .875
Now, if you're looking for a wheel rate of 500#, you'd DIVIDE that by the motion ratio, 500/0.875 = 571
ALL OF THE ABOVE NUMBERS ARE JUST FOR DEMONSTRATION PURPOSES, THEY ARE NOT ACCURATE... THEY'RE NOT EVEN GUESSES. (I know how stuff posted on forums can take on a life of it's own, just thought I'd add that)
Where can i buy a lowering kit and spring 4 toyota yaris S sedan (4 doors) mariosuper Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 07-07-2006 09:06 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
